Old 10-09-2008, 07:13 PM   #1
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Sizing a hitch
As you know, we have two tow vehicles and two Airstreams. The two Airstreams are similar in weight but not in length. The two tow vehicles are not at all similar in carrying capacity or ride quality. In addition, my daughters friend has a 2004 1500 Dodge pickup. I am looking for to size a hitch which would work for both the 1500 Dodge and my 1973 W200 Dodge PowerWagon (which rides like an oxcart). I have a Reese trunnion style hitch now with 1000 lb bars for the Lincoln.
What capacity bars does anyone suggest for the two Dodge pickups?
Bill
Just my personal opinion
Old 10-09-2008, 08:28 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Man, I have a '75 dodge T100 Which is rally a 3/4 ton.. Extended cab,,, well for back then it was.... I have air bags in the springs and it rides like an oxcart also... I don't know about you but my dodge is so stiff, when I hook the trailer up it drops like 1/4 inch maybe... without air in the air bags..
I've had 4200 lbs of rock in the back, air bags full, and only dropped 2 inches... So if your dodge is like mine you may not need bars just sway control....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-09-2008, 08:42 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
The early 70's Dodges are stiff. I had a 1500 lb camper for years and it dropped the rear bumper only 1 1/2". If I use a short draw bar the back does not drop, but if I use the 15" drawbar (which has the sway control) from my Reese the back drops quite a bit because of the leverage.
Bill
Old 10-09-2008, 08:52 PM   #4
purman's Avatar
1968 28' Ambassador
Can you use the sway without the bars??
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-09-2008, 08:54 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
No connector for it on the short drawbar and I still need to size the 1500.
Andy says to always use weight distribution gear.
Bill
Old 10-09-2008, 08:58 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Sizing A Hitch
Greetings Bill!
I have been using 600 pound weight distribution bars with my K2500 Suburban and '64 Overlander with good success. The Reese Dual Cam performs flawlessly with this combination. When I had my '95 K1500 Z71 pickup, its suspension was so stiff that I utilized 350 pound weight distribution bars -- these were offered during the '80s with their then new light weight receiver hitch system -- I have seen them periodically at the WBCCI International flea market, but I don't believe that they have been available from Reese for quite some time.
Kevin
Kevin D. Allen
AIR #827
Need help sizing batteries and charger crdouger Batteries, Univolts, Converters & Inverters 13 03-24-2008 05:21 PM
sizing a converter MarkR Electrical - Systems, Generators, Batteries & Solar 10 05-26-2005 12:09 PM
AC Sizing Over59 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-28-2005 04:41 PM
Furnance sizing Over59 Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-06-2004 12:18 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
