Old 06-06-2010, 12:35 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Size of 600lb Reese Trunnion bars?
I am looking for a pair of 550-600 lb Reese Trunnion bars. Is the diameter 1 inch? What is the overall length?. I have found a pair with no ratings and want to make sure they are the right ones before I buy them. The pair forsale is straight and does not have the curve where the chains are connected--- does that matter? Thanks, Don in Idaho
glacierrunne is offline   Reply With Quote
Old 06-06-2010, 01:03 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The older bars did not have the curve, They used a bolt on piece if it was to be used with the dual cam system. Otherwise the chain bolted to the bar.
My memory says that one inch is right for the 500 lb bars but perhaps someone else will confirm it.
The length of the bar from where it leaves the trunnion to the end should be about 25 inches
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-06-2010, 02:33 PM   #3
If the bars are straight, 1" at the top of the bar, measured at the trunnion, is 450 pounds/.
1 1/8 inch is 650 and 1 1/4 inch is 900 pounds.
Adding the dual cam sway control, adds 100 pounds to each of those ratings.
Old 06-06-2010, 05:46 PM   #4
1980 20' Caravelle
Bought the bars
Andy, Rick, thanks for the information. I bought the bars, and they were marked 750 lbs. I've been using 800 lbs so I am going to try and trade one of my sets for lighter ones! Thanks again, Don
Old 06-06-2010, 06:37 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Interesting article on tuning and older Reese hitch....
Tuning a Reese Hitch
Old 08-09-2010, 08:07 PM   #6
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
nice report
thanks
jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Spring Bars: Round or Trunnion? Any opinions??? Geoffrey Hitches, Couplers & Balls 15 09-09-2009 09:07 PM
Where to buy or exchange trunnion bars? nunya001 Hitches, Couplers & Balls 9 05-24-2009 09:16 AM
Reese round bar or trunnion? erock53 Hitches, Couplers & Balls 21 05-09-2007 10:28 PM
Reese Dual Cam Trunnion Bars dscluchfc Hitches, Couplers & Balls 17 04-21-2005 05:52 AM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
