AV8,
We all had to start somewhere!
You will see as many opinons on which hitch as there are people on this board
I will give you my opinion and which setup I happen to use. I am towing a 31' Sovereign with a loaded weight of around 6300# with a tongue weight of around 650#, these are guestimates until I actually measure them. I use a Prodigy Brake controller. I wish I had bought one sooner. I use the Equalizer WDH hitch. This is a combination weight distributing, sway control hitch. No modifications to the factory reciever/hitch should be required. Here are a couple check out for hitch information:
www.reeseprod.com http://www.equalizerhitch.com/ http://www.nosway.com/ The thing I like about the Equalizer is there is only one basic hook up and you have hooked up both the WD and the Sway Control. I have also used Reese and it is a good product. I have never used the Hensley Arrow but a lot of people swear by it.
Aaron
