Old 03-13-2012, 09:14 PM   #1
loislane's Avatar
2014 23' International
Saint louis , Missouri
Should I worry about rust on my hitch?
Hi all,
I have a 1 yr old equalizer hitch and I'm seeing a lot of rust on it. Do I need to worry about this or treat it in some way. See my photos for examples.
ID:	153319   Click image for larger version
ID:	153321   Click image for larger version
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
loislane is offline   Reply With Quote
Old 03-13-2012, 09:20 PM   #2
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
If it moves, oil (or grease) it. If it doesn't, paint it.
pgr32e is offline   Reply With Quote
Old 03-13-2012, 09:25 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
Worrying about something is kind of pointless unless it goads you to do something useful . A little wire brushing, phosphoric acid and paint will make the rust monster go back to sleep. It is, however, in no imminent danger of falling off due to rust.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-13-2012, 09:48 PM   #4
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
This should be a T-shirt.
Eric H is offline   Reply With Quote
Old 03-13-2012, 11:26 PM   #5
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
You find various rust-inhibitors at any hardware store that work as both lubricant and cover-up. I use a product called "Rust-Check" which is great for black parts... usually twice a year is plenty. It's made in Canada, but maybe they distribute it to the USA or have something similar...
Friday is offline   Reply With Quote
Old 03-13-2012, 11:36 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, it won't hurt a thing, but looks. I take my Equal-i-zer hitch apart randomly, sand the rust off, and paint it with Rustoleum spray cans. It looks better and makes me feel better too. Also while the brackets are off, I repaint the tongue/trailer frame.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-14-2012, 06:52 AM   #7
dznf0g's Avatar
Oswego , Illinois
I paint every 3 - 5 years depending what is looks like. Always inspect for serious rust and cracks, etc. That surface rust is just unsightly, not a structural issue.
-Rich-
Old 03-14-2012, 07:31 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
As noted above regular removal and painting will take care of the "surface" rust.
This on the other-hand requires regular receiver inspections and is much more important.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-14-2012, 10:07 AM   #9
mefly2's Avatar
2015 25' FB Eddie Bauer
I just disassembled, wire brushed, and repainted mine. While the brackets were off, I dimpled and painted an index dot on the upper and lower portion of the frame - we use those index/wittiness marks in aviation to make sure that fasteners haven't loosened. To lessen the wear (repainting need frequency) on the L-brackets, EQ offers a nylon pad that will also reduce the squeaking & grinding noises when turning (see Robert's photo). While I had it off, I also cut off (flush with nut) the extra long 3/4" cross bolts.
Old 03-22-2012, 12:26 PM   #10
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
Robertsunrus--what is the color name that you use on the trailer frame? I'm having trouble finding a dark grey that will match the existing color.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 03-22-2012, 12:40 PM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Lois',
I use a rust remover that doesn't work all that well and then get more rust off with a wire brush and sandpaper and repaint annually. The rust comes back pretty fast, but at least I start out the season looking good. It would take a lot of years before the rust got so bad to worry about, but I think an annual treatment is a good idea.
Any metal that moves against another is going to wear off the paint and rust. Grease or oil helps.
Airstream sells a spray paint for the tongue. It is called "Touch Up" and the color is "pewter gray" (#360260-100). I mixed a rough approximation several years ago out of exterior enamels, but the color never was right. Some searching might come up with an equivalent color. For the hitch, any black exterior enamel.
On a more personal note, there is a Lois Lane in Evergreen, Colorado. There is no Clark Lane or Superman Lane though. And give Clark a chance; there more there than you think.
Gene
Old 03-22-2012, 10:18 PM   #12
Salem , Oregon
Images: 18
Hi, I should have stated that I use Rustoleum Black on my hitch parts, but I use Airstream paint on my frame. I want the right color, not something close. I bought this can of spray paint from Rod at C&G Trailer Service, in Bellflower, Ca.
ID:	154164   Click image for larger version
2005 Safari 25-B
Old 03-23-2012, 07:32 AM   #13
Master of Universe
Gene's Avatar
I have the same can, Bob, and use black Rustoleum on the hitch parts too. The scary thing is I can't remember where or when I got the spray can. For a while I didn't know I had it and then I found it. Next, I won't remember where or how I got the trailer or what all that paint is for.
Gene
Old 03-23-2012, 07:46 AM   #14
I'm sitting here this morning trying to figure out what I need to forget to make room for what I may need to remember tomorrow.
PFC
"Tahawus"
RLC
TX Veteran Designation on Drivers License Bluto Off Topic Forum 43 06-27-2012 12:31 AM
How do i repair my hood fan? Bessie1968 Interior Restoration Forum 6 06-04-2012 03:40 PM
Apparent Hitch height disparity ??? mefly2 Hitches, Couplers & Balls 27 03-15-2012 03:38 PM
More on The Slimp Dolly JimGolden Hitches, Couplers & Balls 17 03-15-2012 04:01 AM
Need crash course on tow vehicles Eaglemate On The Road... 28 03-13-2012 11:12 PM
