09-07-2011, 08:35 AM
1994 30' Excella
Milwaukee
, Wisconsin
Should I Cut the Shank?
I purchased an Air Safe on Craig's list. This is a class VI two year old model. I tow a 30' Excella with a newly purchased Ford Excursion. The receiver on the X will not allow the shank of the hitch to go in far enough to be fastened in the last hole. When I put the pin in and fasten to the first hole the shank wobbles. I had this same problem with my Reese. If I was to cut off about an inch of the shank the receiver would fit into the last hole and be snug.
Obviously once I cut it it cannot be undone so I want to be certain I am not creating a bigger problem.
Chaplain Kent
Forest River Forester 2501TS
09-07-2011, 08:56 AM
2010 28' Flying Cloud
Escondido
Why not contact Airsafe and get the straight scoop ?
09-07-2011, 09:04 AM
Port Orchard
Just an observation:
With every receiver/hitch combination that I can remember dealing with, the shank wobbled when not under load. I would be more concerned with what I may be putting undue stress on when the shank was jammed in to the point of eliminating wobble.
That said, I second what jkcru says.
Ken
09-07-2011, 09:20 AM
2008 27' Classic FB
Burkburnett
If I understand, the receiver won't allow the shank on the Air Safe to slide in far enough. When I ordered mine (new) there was a choice on shank length. It has only one hole for the pin. Wonder if the PO had one with too long a shank and drilled a 2nd hole. I think you will be okay by shortening the shank and hopefully the 2nd hole didn't compromise it's strength. I would contact Air Safe to be sure and have found them to be very responsive.
Camping World sells a special purpose U-bolt intended for this purpose. The bolt part loops over the receiver just forward of the opening reinforcement. Jack up the hitch to take up the slack then fasten the crosspiece against the bottom of the shank and snug up the nuts and the shank won't wobble. If you take your hitch off and on, this can be a pain.
AIR 47751
09-07-2011, 11:02 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
i would contact the manufacturer of the shank. that is the piece than you may be compromising the strength.
i have a friend that used the ubolt anti-wobble thing and wasn't impressed the the durability.
i think i remember some threads on the sloppy fit issue. try doing a google search.
Ricky
09-07-2011, 11:06 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
Ricky
09-09-2011, 09:47 AM
1994 30' Excella
Milwaukee
, Wisconsin
I contacted Air Safe and they said not to tow with the pin in the first hole and I can cut the shank with no problem.
Chaplain Kent
09-09-2011, 11:42 AM
2008 27' Classic FB
Burkburnett
That's good to know, thanks for telling us what you found out.
AIR 47751
09-09-2011, 04:27 PM
1978 31' Sovereign
Oakley
Cut it with a band saw if you can, a plasma or a torch may temper it.
09-10-2011, 12:21 PM
When I got my AirSafe in 2006, it was also a bit long. I took off two or three inches with a cut-off wheel. The hitch continues to perform exactly as advertised, ie, it has provided a great ride and handling improvement when driving over the pot-marked highways from coast-to-coast.
09-10-2011, 01:13 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
I have a Reese Dual Cam hitch, and HAD a bad case of the "wobblies".
I readjusted my brake-controller so the trailer's brake would grab sooner.
While it didn't completely end the wobble, it's no where near as bad as it was.
09-23-2011, 06:49 AM
1994 30' Excella
Milwaukee
, Wisconsin
I should have added that along with cutting the end off, the welding shop put a 1/8" inch plate on the top of the shank, then ground it down so it fit snug but manageable into the receiver. Now I still have a Little wobble to the sides but the biggest wobble, up and down is gone. Today is the first long trip since getting it fixed so am eager to find out how it works.
One other thing, I found the Airsafe Co. to be less than helpful. True, I bought the hitch used and not from them but it is on my truck and will be asked about. I am certain to say the customer service at the company is lacking. I offered to pay for a manual and still could not get one. I got it from Etrailers. Com who were very helpful.
Chaplain Kent
