Old 08-19-2016, 07:58 PM   #1
dasams's Avatar
Marin , California
Shorten Hitch?
We picked up our FC 25 three days ago and are having a great time on our maiden voyage
Our dealer recommended a Husky Center Line and we've had no issues with its performance over the past few days. Upon inspecting the design, it appears to me that I can eliminate a good 2" of hitch length by drilling new holes for the clip. Anyone have any comments about how this will affect performance? It's appealing because it'll reduce tongue weight.
Thanks, Dave
Edit: I see that the pic is rotated 90 deg but I'm on an iPad and can't fix it
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 08-19-2016, 08:38 PM   #2
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
It won't reduce the tongue weight very much. It does shorten the lever arm of the tongue weight on the tow vehicle hitch. It also reduces the torque arm length that acts on the tow vehicle in a sway event and that stability improvement is quite valuable.
CanAm recommends this modification and regularly does it for rigs they set up.
The down side is that on some rigs, the ability to turn sharply is compromised. You should check out trailer to tow vehicle clearance closely.
Edit - if you do, drill small and ream to size. Make sure the hole is perpendicular to the side wall of the shank.
Travel safe. Pat
Need to shorten dinette table leg FCStreamer General Repair Forum 14 07-11-2016 11:45 AM
Shorten crank on roof vent? Breadbug Roof Vents, Skylights & Fans 4 01-31-2011 09:43 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Shorten Draw Bar? dmac Hitches, Couplers & Balls 10 10-23-2003 12:35 PM
Can you shorten an Airstream ? oldvws Repairing/Replacing Floor &/or Frame 9 11-23-2002 10:23 PM
