Got my Propride Hitch Today. Looks real clean and well made. Powder Coat is flawless (white speckel in pic is pacling material dust) I plan on installing late this week or on the weekend.
That's great, Jim! I can't wait to hear what you think of it. Post some pics when you have it installed...or better yet document the installation process!
I've done a ton of research on all brands of W/D hitches, but I did finally decide on the 3P due to the design improvements over the Hensley(HAHA). We just installed our 3P hitch last night. It took about 3 hours with 2 people doing the install. I'd recommend 2 to do the install. The fit was very good although the new paint made a couple of parts a bit tight to install although it wasn't an issue. There were no issues, with any missing pieces or fit of any sort. It came with a double ended wrench to tighten the spring bars, a socket and and extension bar for the hitch bolts. It has 8 line bolts, nice welds, and nice hard paint. I got the extender kit, and now I want to replace the old chains that I have to look as good as the new ones. It was a bit of a learning curve to figure out how the thing really works. We're putting never seize on all bolts just in case and going back over the bolts with torque limiting extensions tonight. Still unsure of how much pressure is needed on the spring bars, but we'll do that tonight too. Think I might call Sean to triple check torque on them. I'm please to say that there were no modifications required to do the install. We're taking a 4500 mile or (with new 16 inch rims and new Michelin L/T tires, 225/75/16, and I've done more research on rims and tire too so let me know if you need any info on them) so round trip leaving soon and will be back late June so more details to come on towing, sway, turning, and backing functionality. BTW, I placed the order for the hitch a couple of months ago and have a trip deadline to meet and Sean Woodruff got the thing shipped in no time. It reached us in 2 days, packed in 4 boxes. I did have a question about the pivot pin placement when doing the install, but he provided his cell phone number and in about 20 seconds he walked me though finding the hole that was right in front of my face...it was actually drilled horizontally into the 2x2 hitch bar that fits into the TV. He is very responsive and helpful, thanks again Sean.
You guys are going to have to start "The ultimate PP users guide" like the one for the HAHA.
Hope the hitch is all you expected and more. They sure look nice.
Man those boxes take a BEATING!
I have the "Sealed Air" rep coming in next week to get the foam in place packaging to see if that will help the box beatings.
Glad to hear you like the Powder Coat. Had a guy tell me he actually dropped the main unit from about 3 feet onto concrete and it didn't even chip it!
Heard another first today too. A dealer installed a hitch for a customer on a new trailer. The customer didn't look at it, and the dealer didn't talk to him about it, and towed all the way home with the over-center-latches not latched on the hitch bar!
Thanks for the kind words, Carl.
You'll get the feel for the weight distribution when you get the whole rig on the road. You can start with them at their maximum and back them down if your ride is too stiff.
Note that on our 31 we hade to take out the pop rivits that hold a bracket, connecting the gas line to the frame in order to install one of the U bolts. We simply used a heavy duty Zip tie to re secure the line to the and it worked fine. It is only necessary to take the rivits out on the forward bracket. We used the industrial size zip and attached to the cross bar which supports the yoke....works fine. Any feedback would be appreciated in terms of the install. What do you guys think,,,does the install look close? Thanks! Jim
That line has always been in the way of getting anything up on the bottom of the frame on the Airstream. You can also bend the hose clamp down a bit to get something between the line and the frame.
Ya with our measurements we were right on top of the airstream connection point with the clamp that attached the gas line. So we just opted to give things a little more flex room and tie it in with a heavy zip. Someone elses measurements and a slightly different connection point by airstream and it could have been accomodated with a bend. Each situation I think will be slightly different. All in all the install wasn't difficult. Now I want to get some time on this baby abd I will let you guys know....just took it down the road a few miles tonight. So far so good. Jim
PS Boy that wiring situation to the break away is really stupid the way the tank cover crimps down on the wiring. I'm getting some heavy rubber pieces of something under there to give it a bit of breathing room. You would think with new units off the line ....this nagging little issue would have been resolved by now.
