Old 09-29-2017, 02:02 PM   #1
RobH41's Avatar
2001 25' Safari
1977 Argosy 20
Nashville , Tennessee
"Shocker" hitch?
Anybody have any experience with the "Shocker" hitch ball mount? I've been in a conversation about it with a user that contends that it would replace an equalizer bar type hitch. I don't see how that would work, but thought I'd check with our community? Any comments?
http://shockerhitch.com/Receiver_Hitch.php
Thanks (I'm not planning on replacing my equalizer hitch with one!)
Rob
2001 Safari 25 with custom install Eddie Bauer rear hatch door. TV is 2006 LBZ GMC 2500HD with Gale Banks Engineering engine package. 40 gallon Aux. diesel tank. Front maneuvering hitch. Rancho XL shocks. WBCCI 5173
RobH41 is offline   Reply With Quote
Old 09-29-2017, 02:06 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
"Shocker" hitch?
I dont see any sway control or weight distribution incorperated into that hitch design. Looks like its designed for utility trailers that you tug around town for work at low speeds.
Its basically the same as towing on the ball without WD or sway control. I wouldnt do it even with my 2500.
wulfraat is offline   Reply With Quote
Old 09-29-2017, 03:49 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
It's just a gimmick to reduce the "up and down" from the trailer. It does zero for WD. It also does zero for sway.
Old 09-29-2017, 04:53 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
While I have no direct experience in this area, I know a couple of people who tow with AirSafe hitches. They provide that same up-and-down cushioning but allow the use of normal WD and sway control systems.
David
DKB_SATX is online now   Reply With Quote
Old 09-29-2017, 06:36 PM   #5
Kevin245's Avatar
The Shocker hitch isn't a "gimmick" but it isn't designed to used with WD. The Air Safe unit provides pneumatic cushioning and has WD capability.
We picked up an Air Safe hitch a few years ago and it really eases the shock when towing over rough roads.
Eleanor Roosevelt
Old 09-29-2017, 06:44 PM   #6
wulfraat's Avatar
"Shocker" hitch?
How does it transfer weight when the coupler can freely rotate around the ball? How is external leverage applied?
For all intensive purposes this looks to be a simple WC (weight carrying) hitch vs a WD (weight distribution) hitch.
Old 09-29-2017, 06:54 PM   #7
Kevin245's Avatar
Originally Posted by RobH41 View Post
Anybody have any experience with the "Shocker" hitch ball mount? I've been in a conversation about it with a user that contends that it would replace an equalizer bar type hitch....
It will not function as WD hitch as indicated in their website FAQ's http://shockerhitch.com/FAQs.php
Eleanor Roosevelt
Old 09-30-2017, 07:04 AM   #8
RobH41's Avatar
2001 25' Safari
1977 Argosy 20
Yep...that's my take on it as well. I don't see any of the design physics that would allow it to replace and do the same function as a WD hitch system. I guess it would help some to help dampen vibration and jounce on really rough roads, but I see it more as a device looking for a buyer more than a any real necessary use for most trailer use.
Old 09-30-2017, 07:24 AM   #9
2016 27' Flying Cloud
Little rock , Arkansas
I use a shocker hitch with my F250 and 27fb. Works great for me.
Dtrentr is offline   Reply With Quote
Old 09-30-2017, 12:11 PM   #10
RobH41's Avatar
2001 25' Safari
1977 Argosy 20
So you don't use a WD hitch with your 27fb?
Old 09-30-2017, 12:20 PM   #11
No I do not.
Old 11-11-2017, 09:04 AM   #12
"Hey, I know you!"
Boog's Avatar
2012 23' Flying Cloud
Irmo , South Carolina
I just got back from a 1200 mile round trip (SC to FL) using my Shocker hitch and everything worked perfectly. Books and plastic utensils stayed exactly where I left them on the table, cushions never left the couch and there were no jolts and bouncing from the trailer to the truck or visa versa.
Here is what I posted about towing without a weight distributing hitch http://www.airforums.com/forums/f464...ml#post1926383 and here's proof that weight distribution can be done by effective loading of the tow vehicle: a 2001 2500HD Chevy regular cab long bed pulling a 2012 23D. Not everybody can get similar results because of their tow vehicle/trailer combo, but this set-up works well for me.
Boog is offline   Reply With Quote
Old 11-11-2017, 10:53 AM   #13
Mollysdad's Avatar
Impressive. How did you keep the trailer from going up and down over road imperfections? What tire pressure did you run? Did you take I-95 or I-75? I've done both and although I thought they were pretty good, every so often the trailer got a bounce from a road imperfection (often where repaired). Silverware stayed on the table?
Old 11-11-2017, 10:58 AM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The great thing about towing...... everyone can do it as their own way.
But my way is better.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
"Tahawus"
hitch with "off" and "on" to control as bars dlenloe Hitches, Couplers & Balls 1 06-10-2017 08:20 AM
Shocker Hitch CBWELL Hitches, Couplers & Balls 15 09-26-2014 11:20 AM
Shocker Hitch 2wired Hitches, Couplers & Balls 17 03-07-2012 09:41 PM
Steering components shocker bkahler Mechanics Corner - Engines, Transmission & More... 2 06-14-2007 04:54 AM
