Old 05-25-2014, 02:38 PM   #1
2008 23' International CCD
Denver , Colorado
Shank length ok?
We just swapped TV to a 2003 Toyota 4Runner V8 from a similar 2003 4Runner V6. The receivers are different - V8 has more of a weight distribution receiver.
When I slipped the Reese shank - the part that slides into the receiver - into the V8 receiver it didn't slide in as far as on the V6 but it did slide as far as it could up to the spare tire. I inserted the locking pin, took measurements with vehicle and trailer parallel to the ground, raised the hitch head (ball mount?) to make sure the trailer and vehicle are level. All seems well.
Except I'm worried about the difference between this shank's position in the V8 receiver and the old V6 receiver. The shank might be in the right place for the V8 receiver, but it's farther outside the receiver by the width of the rust band on the shank from the prior setup (perhaps 1.25"?).
Can I drive with this, or is there a different Reese shank I should get? I didn't see reference to a different shank length on the Reese site; just different height adjustments and we don't need that.
See photo attached of the V8 receiver and the rust band. Is this safe?
Name:	Tongue in receiver.jpg
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 05-25-2014, 03:56 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The weight rating is what is important. What is the rating of the receiver hitch on your new TV. Class III or IV? What is the rating of the shank? Both should exceed the weight of the trailer as well as the tongue weight.
Old 05-25-2014, 04:05 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Shank length ok?
I wouldn't think twice about using the receiver/shank as pictured.
It will be fine.
Old 05-25-2014, 04:14 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, repaint the rusted area, you'll be fine.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-25-2014, 07:55 PM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
It is fine, hope you don't get in a hurry.
Old 05-26-2014, 10:52 AM   #6
Denver , Colorado
Thanks J. Morgan - we plan to do just that. And give it a spray of paint too.
Jim and Marsha
"Tow'd Hall"
AIR #35886
Old 05-26-2014, 10:53 AM   #7
Denver , Colorado
Yeah, a shot of Rust-O-Leum should do the trick. Thanks.
Jim and Marsha
"Tow'd Hall"
AIR #35886
Shank length kentlundy Hitches, Couplers & Balls 5 09-04-2011 08:16 PM
How do I Install an Adjustable Shank on my Hitch?? SmokelessJoe Hitches, Couplers & Balls 23 05-19-2008 09:18 PM
Shank too long for Reese Hitch? Bakes5 Hitches, Couplers & Balls 8 04-19-2007 06:57 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 12:30 PM
