Old 10-19-2016, 03:16 PM   #1
2016 16' Sport
Miami , Florida
Shank clearance
Hi
I have a 2015 grand Cherokee and a 16 sport. I have an equalizer hitch. In order to get the trailer level I have to use a shank that leaves only about 8 inches of ground clearance. Is this normal? I'm just wondering what others with the same setup have.
Shiny16 is offline   Reply With Quote
Old 10-19-2016, 05:11 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Do you have a picture?
Bill
Originally Posted by Shiny16 View Post
Hi
Just my personal opinion
Old 10-19-2016, 05:14 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yes, I might even have a bit less on my JGC using a Blue Ox Sway Pro.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 10-19-2016, 05:18 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Do you have to use a long shank to lower the head to match the trailer tongue height? 8" is probably enough clearance unless you plan to tow on dirt roads to boondocking sites.
What shank are you using? The link shows all the 2" shanks available.
http://www.equalizerhitch.com/store/...dex&cPath=3_15
Kelvin
Old 10-19-2016, 06:03 PM   #5
2016 16' Sport
Miami , Florida
I don't really understand the numbers but it's the 9 inch drop actually 13 long. The second one down under the best sellers.
Old 10-19-2016, 06:05 PM   #6
2016 16' Sport
Miami , Florida
Thanks.
Have you had any issues with bottoming out?
Old 10-19-2016, 06:16 PM   #7
dasams's Avatar
Marin , California
Take it to a machine shop and have the bottom few inches cut off.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 10-19-2016, 06:25 PM   #8
AWCHIEF's Avatar
Images: 33
Thanks.
It will make contact coming in and out of my drive way if I do not raise the adjustable suspension on the Jeep. Also have to be careful at some gas stations and steep angle campgrounds.
MICHAEL
Old 10-19-2016, 06:32 PM   #9
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
I have the same issue. To get the Airstream level mine is close to the ground as well. Just completed a 4,200 trip we hit twice. I keep it in sport mode but you can raise it to off road 1 if you know you will be close. 2015 jgc 31' airstream.
tcrum is offline   Reply With Quote
Old 10-19-2016, 06:47 PM   #10
2016 16' Sport
Miami , Florida
I don't have the adjustable suspension. There is actually 7.5 inches of clearance. I spoke with equalizer and they said it's ok to cut off the access as long as you don't cut above the last unused hole. I have one hole unused. I can cut just about 1 inch off the shank.
Old 10-19-2016, 06:51 PM   #11
2016 16' Sport
Miami , Florida
Thanks. I assume the time you hit were at slow speeds and kinda expected?
Clearance clearance LEDs mayco Classic Motorhomes 55 04-29-2016 04:41 PM
Deep drop WD hitch shank ground clearance? mountainboy Hitches, Couplers & Balls 5 07-20-2009 04:56 AM
Shank too long for Reese Hitch? Bakes5 Hitches, Couplers & Balls 8 04-19-2007 06:57 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 12:30 PM
