Old 03-08-2019, 08:43 AM   #1
2018 23' International
Guilford , Connecticut
Same Equalizer with new t/v ?
Hi folks,
We recently replaced our Tacoma with a new Tundra for more capable towing of our 23FB. The trailer and Tacoma combo was set up with a Equalizer with 600 lb bars when we purchased the trailer last summer. Since the trailer weight and tongue weight will theoretically remain the same, should we still be good with the same 600 lb Equalizer setup?
I've looked at the Equalizer site where they have a selection tool which will select the correct hitch based on gross trailer weight, tongue weight, and cargo weight. It indicates the 600 lb hitch will still work until we go over 200 lbs cargo weight behind the rear axle, (the Tundra payload is only 150 lbs more than the Taco), but since we are newbies with this I was hoping for some input from veterans.
Many thanks.
Pop & Mimms - because our grandchildren say so
2018 23FB International Serenity "Pimm's Cup"
2019 Tundra
Pimms is offline   Reply With Quote
Old 03-08-2019, 11:09 AM   #2
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
You should be fine. Just don’t have a lot of bed load behind the axle, as they say.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 03-08-2019, 11:12 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
You may have to change the height of the hitch head due to different height of the TV receiver, but everything else should be OK. It would probably be difficult to get 200# of stuff behind the rear wheels. Also, I find the Equalizer tool to lean toward the heavy bars. It recommended 1000# bars for my Safari 25. After reading on here about stiffness of Equalizer bars, I machined mine down to 750# rating.
Al
Old 03-08-2019, 11:14 AM   #4
1987 25' Sovereign
Oops — I didn’t mean with the same setup, I meant with the same Equalizer. You’ll probably need to readjust the setup for ball height of the new TV and maybe the pitch (angle) of the hitch for proper weight transfer and trailer leveling.
Alumacoot
Old 03-08-2019, 12:06 PM   #5
Mollysdad's Avatar
It will work fine.
You'll know how to set it up.
Old 03-08-2019, 02:37 PM   #6
2017 19' International
Tallahassee , Florida
Do you mean that literally?
WhereStream is offline   Reply With Quote
Old 03-08-2019, 05:51 PM   #7
2019 30' International
Pennsylvania , Pennsylvania
Go through the setup process as per Equalizer manual. That's what I did when moving from an F150 to an F250 and it worked out fine.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 03-09-2019, 10:00 AM   #8
2019 27' Globetrotter
Pleasanton , California
I reused mine when going from 4Runner to F150. Only head hight change required.
fubar201 is offline   Reply With Quote
Old 03-09-2019, 10:13 AM   #9
2007 27' International CCD FB
San Diego , California
It should work great.
As others mentioned, you may need to change the ball height.
Also, be sure to keep the ball as close to the rear bumper as possible if the drop shank or insertion depth needs to be changed.
pteck is offline   Reply With Quote
Old 03-09-2019, 10:52 PM   #10
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Reset the height allowing for one inch of sag and give it try fully loaded. Then if you need more spring bar get the next larger size. the worst mistake people make with hitches is too much spring bar and that equates to trough ride for the TV/TT.
guskmg
Old 03-10-2019, 03:52 PM   #11
Thanks to all for your replies. We're relieved to hear it should work and hoping we can still fully open the tailgate on the Tundra with the Equalizer properly installed and the trailer hitched up. The gate on the Tacoma just barely cleared the tongue jack.
2019 Tundra
Same old, same old whitegs Tow Vehicles 36 08-11-2016 03:22 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 07:23 PM
New name same lady! norcalcindy Member Introductions 2 03-08-2008 08:27 PM
New laptop,same old problem! Help wanderer1 Forum Admin, News and Member Account Info 22 09-13-2007 10:40 AM
Help we need a new key ..are they the same? Julie R Doors & Locks 7 08-13-2007 08:52 PM
