Old 04-13-2005, 11:56 AM   #1
Safty chain
stupid question, probably been covered, but how much slack should the safty chain have?
I have been told it dosen't need any at all, to give it plenty?? And where do most of you hook the safty brake wire.
the dealer said that it was ok to just twist the chain until you feel comfortable with the amount of sag.
imagine is offline   Reply With Quote
Old 04-13-2005, 12:08 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Thumbs down
Ideally, you should have enough slack in the chain to be able to turn the rig without binding or breaking the chain, but able to keep the tongue of the trailer off the ground if the trailer comes off the ball mount.
You can hook the cable for the breakaway switch somewhere secure on the tow vehicle so that if the trailer comes off and before it gets away, it will actuate the trailer brakes, hopefully stopping it in time to avoid turning a disaster into a catastrophe.
Old 04-13-2005, 12:47 PM   #3
Elgin , Texas
Images: 164
I'm amazed on a daily basis on how many trailers I see where they are using the safety chains, but not crossing them.
bake315 is offline   Reply With Quote
Old 04-13-2005, 01:04 PM   #4
Amazed?
What amazes me is the trailers I see on the highway dragging chains, wires and running gear on the pavement. The chains make quite a show at night, but I don't stick around to watch.
bobechs is offline   Reply With Quote
Old 04-13-2005, 01:08 PM   #5
Well Preserved
1993 21' Sovereign
Question
Yes, the crossing of the chains was something of a habit that I do so much, I never even thought to include it in my post...
Old 04-13-2005, 01:21 PM   #6
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
And having lost a 15' Trillium 4500 fiberglass camper trailer at 65mph last spring, when it jumped the hitch ball from having a worn hitchball socket, I can tell you first hand just how important those chains are! I got the rig stopped and the only damage incurred was the electrical pigtail being ground through, and one safety chain being ground off the tongue. It was a miracle that the bouncing trailer didn't take anyone else out, and it stayed on it's wheels... although I thought for a while it was going over onto it's side....
USE YOUR CHAINS and HOOK THEM UP PROPERLY!
Roger
Old 04-13-2005, 01:38 PM   #7
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Safety Chain Towing Tips
  • SAFETY CHAINS ARE REQUIRED BY LAW IN ALL 50 STATES -Please check with your state's Department of Transportation for their minimum requirements.
  • Equip your trailer with two (2) safety chains equipped with latches to prevent the hooks from disconnecting from the trailer.
  • Safety chains should be installed in a crisscross fashion under the hitch of your trailer. This is intended to keep the hitch from hitting the ground in the event of a failure.
  • Allow only enough slack in each chain to allow for non-binding turns.
  • The chains should be short enough to hold the tongue of your trailer from touching the ground should it become disconnected.
  • Make sure the safety chains are connected to a secure point on either your trailer hitch or the frame of the tow vehicle.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 04-13-2005, 02:14 PM   #8
markparker22's Avatar
1984 31' Excella
Santa Barbara , California
Imagine:
Thank you for starting this thread. "There is no such thing as a stupid question." Your question caused me to review the safety chain set-up I use on my Pullrite hitch. Pullrite hitches operate differently from the classic hitch. Because of the Pullrite design where the Weight Distribution bars connect the Trailer hitch to the receiver in a "rigid" fashion (and the receiver is at the end of a long radius arm that pivots under the Tow Vehicle) it became obvious to me that the safety chains should be tight. The reason they should be tight is that the Pullrite hitch loses its control method if the trailer hitch becomes seperated from the receiver ball far enough for the Weight Distribuition arms to slide out of the Receiver. In an emergency separation if the Weight Distribution arms seperate from the receiver then the radial arm under the Tow Vehicle is no longer rigid with the Trailer hitch (Trailer itself also pivots) and the radial arm will slam into the end stops on either side of the radius track under the Tow Vehicle when your emergency stop occurs.
The tight connection of the saftety chains described here is meant for Pullrite hitches only because of their unique design.
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 04-13-2005, 02:28 PM   #9
Elgin , Texas
Images: 164
Originally Posted by markparker22
Imagine:
Right, so if you try to connect your safety chains to some part of the tow vehicle other than the pivoting radius arm of the hitch itself, you've effectively canceled out the pivoting characteristic of the Pullrite.
Old 04-13-2005, 02:39 PM   #10
1984 31' Excella
Saftety Chains on Pullrite Hitch
Coriolis1:
Yes, the Pullrite saftety chains must be connected to the radius arm itself. The Pullrite design has substantial safety chain connection points on the radius arm.
Mark
AIR No. 2375
Old 04-13-2005, 04:47 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've been told that twisting the chains to shorten them is not a good practice and can have some adverse affect on the weight they can carry. I'll check this out further for a little more info.
At least on newer Airstreams, the final link has a removeable pin and a cotter key. You can connect that link to a link further up the chain and effectively shorten the chain. The excess I just wire tie to the existing chain. It works great. I did this on my 2001 Safari and on the current Classic that I have today.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-13-2005, 06:32 PM   #12
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Twisting chains is a bad thing to do. One of the main things I learned in the oil field, a good way to brake a chain and get hurt fast. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-14-2005, 11:25 AM   #13
Thanks!!
Thanks a LOT for all the HELP!! Some great information, and ideas!!
The $14,938.63 Filter! Chaplain Kent Mechanics Corner - Engines, Transmission & More... 64 05-02-2005 07:02 AM
History channel special on 16' CCD yukionna Our Community 61 04-17-2004 04:25 PM
Safety Chain Restraint Navigator On The Road... 3 02-28-2004 10:20 AM
Safety Chain Shaclkle - Weakest Link? Creampuff Hitches, Couplers & Balls 6 12-09-2003 06:46 PM
Safety chain femuse Hitches, Couplers & Balls 4 04-19-2003 08:26 AM
