Old 03-20-2017, 12:11 PM   #21
CRH
1995 25' Excella
xxxxx , xxxxxx
The flimsy looking split ring welded on the front of my trailer looks like the weak link in the chain set up.
CRH is online now   Reply With Quote
Old 03-20-2017, 02:08 PM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Absolutely cross!
Cross and cradle-
The reasoning/logic behind cross and cradle:
If the trailer becomes uncoupled from the ball, the crossed chains will catch the trailer coupler, a-frame, and tongue jack and prevent them from hitting the ground and causing more damage.
The chains must be just long enough to make sharp turns without binding.
If the chains are too long, crossing them will not do what it is supposed to do.
If the chains are to long, take up extra links by zip tying them together or using key rings to take up the slack in the chain links.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-20-2017, 02:45 PM   #23
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Agreed!
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 03-20-2017, 03:11 PM   #24
Yertle01.com
TRizzuti's Avatar
2006 22' International CCD
Estes Park , Colorado
I learned to cross the chains in a boating class that had a section on towing safety. Made sense to me then, makes sense to me now -- cross the chains.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
TRizzuti is offline   Reply With Quote
Old 03-20-2017, 03:21 PM   #25
Flying Cloud 27
smlbob's Avatar
2015 27' Flying Cloud
Union Hall , Virginia
I agree with others - chains should be crossed. I had a small utility trailer jump off the ball once, and the crossed chains caught the hitch and kept it off the ground as I came to a halt.
smlbob is offline   Reply With Quote
Old 03-20-2017, 03:24 PM   #26
CRH
1995 25' Excella
xxxxx , xxxxxx
I had a 2500 lb trailer come off the ball at 70 mph. The cradled chains caught it. I was able to pull over safely and had no damage.
Old 03-20-2017, 03:32 PM   #27
Rivet Polisher
1973 31' Sovereign
Mt Pleasant , North Carolina
Far from it, if the trailer separates from the TV it will drop. If this ring was welded to the top it would only rely on the welds, being welded on the bottom it now supports the tongue and the welds are simply to keep it in place. Chances are the rest of the trailer will disintegrate long before that split ring will separate.
Always Cross the chains
PS. All you have to do is watch "trailer races" on Youtube to see that the ring will outlast the trailer.
wildhorses is offline   Reply With Quote
Old 03-20-2017, 03:53 PM   #28
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
My trailer chains are both welded to the same single location under the tongue. What's the benefit of crossing in this instance?
kscherzi is offline   Reply With Quote
Old 03-20-2017, 04:05 PM   #29
dznf0g's Avatar
Oswego , Illinois
Not much probably...other than the law in many (all??) states says they gotta be crossed.
-Rich-
Old 03-20-2017, 04:10 PM   #30
MWBishop's Avatar
Huntsville , Alabama
The Trailer Races vid is awesome!
However:
1. Notice you DON'T see in Airstreams (for good reason, right).
2. At one time each and every one of those TVs and trailers were someone's pride and joy. How sad, but at least brought one last bit of joy in their deaths.
3. What a HUGE mess to have to clean up.
2017 Airstream 26U Twin
2017 F250 Platinum
MWBishop is offline   Reply With Quote
Old 03-20-2017, 06:33 PM   #31
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by m.hony View Post
Absolutely cross!
Cross and cradle-
"ZIP TIES"?? "Key rings?" THE chain will STILL be too long, when the hitch 'decouples'.
Cut enough links off to make a proper length chain.
MelGoddard is offline   Reply With Quote
Old 03-20-2017, 06:33 PM   #32
dznf0g's Avatar
Oswego , Illinois
Uh, yup.
-Rich-
Old 03-20-2017, 06:57 PM   #33
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
Mine came loose one time, pulling a 27' AS. This was after several years of towing. Definitely glad the chains were crossed!
WindyJim is offline   Reply With Quote
Old 03-20-2017, 07:00 PM   #34
2007 25' Classic
Hutto , Texas
Besides the unlikely need to catch the tongue if the hitch breaks, there is a more mundane reason to cross the chains when the tv anchors are spaced a little.
If you do not cross, in a turn the inside chain will droop and the outside chain will bind. By crossing, the chains stay closer to the same height.
Wanderer2604 is offline   Reply With Quote
Old 03-20-2017, 07:22 PM   #35
m.hony's Avatar
2013 30' Classic
Originally Posted by dznf0g View Post
Uh, yup.
The logic behind cinching up extra links:
If you cut them to length for a certain tow vehicle, then it hey will be too short for another.
The zip ties will break if the trailer is uncoupled.
The key rings will distort/stretch/break.
Damage will still be minimized.
Airstream puts key rings on the chains from the factory.
Another option, though not recommended, is to twist the chains to make them shorter.
The reason they say to not twist them is that it supposedly weakens the chains, although I can't see how or why.
TAC #MS-10
Airforums #70955
Old 03-20-2017, 07:26 PM   #36
dznf0g's Avatar
Oswego , Illinois
I disagree with all in this post. Proper length chains with no "cheaters" for each application is the only prudent way to ensure proper behavior during a disconnect. Just make chains for the longest application and move the hooks on the links to shorten. Use a clevis hook rated for the job.
Never twist chains to shorten. This reduces strength during high loads.
-Rich-
Old 03-20-2017, 08:01 PM   #37
2004 22' Safari
Albuquerque , New Mexico
A little off topic, but do you pull a 30 foot AS with a Tundra (I see them both in your signature block)?
Silver.Sanctuary is offline   Reply With Quote
Old 03-20-2017, 08:31 PM   #38
m.hony's Avatar
2013 30' Classic
Safety Chains: Cross or Not to Cross
Anther way to shorten without cutting:
Use one of those links with the threaded portion that can be opened to gather up the extra links.
Or is that a Clovis hook?
TAC #MS-10
Airforums #70955
Old 03-20-2017, 08:36 PM   #39
dznf0g's Avatar
Oswego , Illinois
No, a clevis hook is a hook for the TV end of the chain which attaches to the chain with a clevis pin. Yes, you could use a threaded link. Each piece, hook or link, should be rated at or above trailer gvwr for breaking strength.
-Rich-
Old 03-20-2017, 08:51 PM   #40
2017 27' Flying Cloud
Sulphur , Oklahoma
You can twist the chain if it is to long as in touching the ground but you do need slack in the chain.
Dennisr is offline   Reply With Quote
Safety Cables versus Chains Ganglin Hitches, Couplers & Balls 74 05-23-2013 11:01 PM
safety chains: too long/not too long? kfrere Hitches, Couplers & Balls 16 04-27-2009 11:14 AM
Replace Safety Chains..? Ganglin Hitches, Couplers & Balls 3 11-13-2006 09:09 PM
Safety chains: A message from Airstream Rog0525 Hitches, Couplers & Balls 0 05-02-2003 07:14 PM
Safety Tow Chains pap Hitches, Couplers & Balls 4 04-11-2003 11:16 AM
