08-10-2014, 04:31 PM
2013 27' FB International
El Dorado Hills
Safety Chain Worn - How Did this Happen?
I have a mystery. As I was unhooking today I noticed the safety chains are both badly worn, as if almost filed through. One link is nearly gone. I know... first thought, dragging on the pavement. Except these links are the first and third links next to the tow vehicle. The middle and lowest hanging links are just fine. More, the mystery is the amount of rust on the wear locations so it didn't happen recently.
My trailer is barely over one year old. I've only towed it about 3,500 miles since purchased and the safety chains are badly worn and ruined. No evidence of any unusual wear on tow vehicle hitch, nor on the Equalizer hitch. Any ideas? Photos follow.
Notice the wear on the third chain link.
This photo shows the wear on the first link.
Another view of the damage.
Photo of damage to link on second chain (fourth link).
A view somewhat replicating the look when hitched. The chains typically hang about 3" above the pavement at bottom. The problem links are towards the front near the tow vehicle, nowhere near pavement. I've never let them drag or forgot to clip on when towing. Due to the amount of rust I know the damage hasn't been reoccurring, at least not lately. I'm stumped. In the short run I thinking of just cutting the bad links out and living with shorter chains. Any thoughts?
- Kurt
08-10-2014, 04:50 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
That is abrasion damage, somehow, somewhere those chains have dragged against something. You could cut them out as long as it doesn't shorten the chains too much.
Aaron
WBCCI #XXXX AIR #2495
08-10-2014, 05:39 PM
2012 25' Flying Cloud
Battle Lake
Were the chains shortened when you had the Andersen hitch, and the extra links in front left on but contacting the ground?
Doug and Cheryl
08-10-2014, 06:13 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
Sure looks like road rash to me.
Garry
08-10-2014, 08:00 PM
El Dorado Hills
Since the third link appeared weakened beyond sensible, I cut it off, basically shortened the chain. I have a couple of chain shackles I can use if needed to re-lengthen the chain. The other end is welded onto the Airstream frame. I've never previously cut nor did anything special to the chain, just attached to the same TV as always and took off.
What's strange is the wear pattern. It was obviously ground down against something abrasive, but also held in one position and under pressure. Note how the metal curls up to the side of the grind area. This would seem to omit random pavement abrasion. This is one year old trailer.
I'm stumped. I almost wonder if this is how it came from the factory, or damage happened on way out. The rust would imply some age.
The wear pattern is totally flat. As if secured and pressed very hard against an abrasive. So hard some of the metal curled back over the sides. Strange.
This link was attached directly to the snap clamp that attaches to the tow vehicle. The snap clamp is fine, no wear whatsoever. Link #2 shown here on left is fine.
08-10-2014, 08:11 PM
This is road rash.
William C. Swinney
08-10-2014, 08:19 PM
1948 22' Liner
Roy
, Utah
I've seen damage on two separate links like this before, and it is rare up near the hooks or at the attach points. I've had owners come in with this kind of damage and have admitted to twisting the chains to take up the slack. The chains rub together in a twisted fashion and the is what it looks like.
I'm not saying that you did twist your chains, but if the link was twisted by accident and you had a long road trip without disconnecting, it is a possibility. And with cheaper and cheaper chains hitting the market they don't take chaffing contact like an expensive set of chains.
I personally ride with my chains five inches of the ground with my hunting trailer. I also permanently set the length so I do not have to do any kind of twisting or zip tieing or links to get the correct hight from ground each time.
"Some things you can tap. Some things you can hit. Know which one is which!"
1948 Airstream Liner 22'
08-10-2014, 08:44 PM
1999 34' Excella
Hillsboro
I use a bungee cord to hold chain off the ground
Peace and Blessings..
Channing
WBCCI# 30676
08-10-2014, 09:29 PM
2000 19' Bambi
mt. Prospect
Perhaps the chains were dragged by the hauler who delivered the trailer to your dealer, and you didn't notice until they rusted up and became obvious?
08-11-2014, 05:45 AM
Mantua
, Ohio
I like the twisted chains idea. Makes perfect sense. Could also be road rash. Jim
08-11-2014, 06:33 AM
2014 28' International
Blacksburg
, Virginia
dragged?
I agree with Robert Claus, they may have been dragged by the delivery hauler, and maybe they put new hooks on the end because they were booger-ed up a bit like the chain?
Is those add a links ok to use? Are they as strong? I'd like to add a link or two to my chains cause I think the are little tight in a turn. I haven't used any of those before.
Have a good one,
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
08-11-2014, 07:56 AM
2006 30' Classic
Milton
Who Did It?
A view somewhat replicating the look when hitched. The chains typically hang about 3" above the pavement at bottom. ...
- Kurt
You probably did not cause this damage. Would it be possible to contact the previous owner, or selling dealer, to discuss this issue with them? They might be able to shed some light on the cause.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
08-11-2014, 08:03 AM
2022 Atlas
Homosassa
I would just put on a new set of chains and call it a day. It's road rash.
08-11-2014, 09:17 AM
Biloxi
, Mississippi
Ditto what Tater said. New chains are cheap. Not worth loosing sleep over or bothering the P.O..
MICHAEL
08-11-2014, 09:25 AM
As mocked up in your last photo, the chains look to be a bit too long. Cutting them to the desired length and removing the damaged links would be my approach of there is no other area of significant wear.
William C. Swinney
08-11-2014, 10:22 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Folks,
Anybody curious or comments on the angle of the un-hitched bars of the hitch in Kurt's last pic?
I don't have the same TV so I don't have any baseline to compare to.
Gary
08-11-2014, 10:51 AM
1976 31' Sovereign
Oswego
Looking at pics. chain should be crossed beneath hitch for added safety, because if trailer breaks loose will stop from dragging on ground causing more damage, also many states it is required to cross chains, as for wear probably done before you pur. trailer
08-11-2014, 01:03 PM
1974 Argosy 20
Kooskia
, Idaho
On the new Airstreams the chains are attached at a single center point under the tongue. There is no way to "cross the chains" as can be done on the older rigs which had the chains coming from two loops, one on either side of the trailer tongue.
If you look carefully at the photo showing the chains and how they are set up, you will see what I mean. My 2014 FC 20' has this single point attachment system and I think all new ones use that same system now.
08-11-2014, 01:40 PM
Sneedville
, Tennessee
Not mine, they are on each side of the tongue and can be crossed. 2014 25' FC
08-11-2014, 01:42 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
My thoughts as well ... use a bungee on the new chains to hold them higher ... I would completely replace all the chian and attach with quick links or screw links for ease of adjustment / replacement.
As an aside, I would also cut off those extra long cross bolts on your EQ hitch ... have you left leg skin on them yet?
