Old 09-28-2007, 07:06 PM   #1
87MH's Avatar
1978 31' Sovereign
Images: 292
Safety Chain on Inside or Outside of Equalizer Bars?
Does anyone have a reason to (or not to) route the safety chain on the outside of the equalizer bars?
I currently have mine routed to the outside, but they are rubbing on the outside of the equalizer bars.
It just does not "look right" when I leave them inside of the bars (chains are crossed under the tongue).
I'd appreciate any input, and the reasons why the chains go on the inside - or the outside.
Thanks in advance.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-28-2007, 07:12 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
On our hitch set-up, our chains are crossed underneath the tongue, but fall inside the Equil-i-zer bars... Here's a picture...
TB
Name:	Loaded to Go Sep07_02_Sm.jpg
Old 09-28-2007, 07:49 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I keep 'em inside and crossed side to side.
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 09-28-2007, 08:09 PM   #4
2006 30' Classic
Farmington , New Mexico
Images: 14
Thanks in advance.
like tb and moose i cross mine and they hang inside the bars---my 2 reasons. ----should you uncouple while towing ,theorectically?,the tongue should be kept off the road by falling on the crossed chains. my2nd reason is that the bars are in fact springs. Its my undertanding that scratches , even small ones can cause a spring to break. ---pieman
Mike Lewis is offline   Reply With Quote
Old 09-28-2007, 08:22 PM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
chris cross
Crossed on the inside.
ArtStream is offline   Reply With Quote
Old 09-28-2007, 08:24 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
ditto.
john
you call them ferrets, i call them weasels.
Old 09-28-2007, 08:34 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Originally Posted by john hd
ditto.
john
double ditto
Richard
Old 09-28-2007, 09:13 PM   #8
Babeebloos's Avatar
1963 19' Globetrotter
Laguna Beach , California
Images: 24
Triple Ditto .... BINGO!
Officer says ..."Step AWAY from the toaster Ma'am"
http://www.debraschottfineart.blogspot.com
Babeebloos is offline   Reply With Quote
Old 09-28-2007, 09:47 PM   #9
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
quadruple ditto!
Michelle TAC MT-0
Sarah, Snowball
Old 09-28-2007, 09:59 PM   #10
Dan Clayton's Avatar
1956 22' Flying Cloud
West Linn , Oregon
Images: 14
ALWAYS Run them on the inside, as well as wrapping around themself's two or three times or more. This is done so if the hitch mount ever breaks, which they can, the hitch of the trailer will drop on to the chains and will not hit the ground. If they were not wrapped they would hit the ground, and the swing back until the chains were tight and then shoot forward and push your rig right off the road. Take it from someone that it's happed too, it's no fun.
Dan Clayton is offline   Reply With Quote
Old 09-29-2007, 04:46 PM   #11
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I agree inside.
But I strongly disagee in wrapping any chain, that comprimising its breaking strengh.
The links should be free of twist or knots.
If you are wraping them because they hit the ground, use a bungee or cut them to fit correctly.
'77 Sovereign Intl 31' CB
Old 09-29-2007, 04:52 PM   #12
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
It's unanimous - chains inside bars.
Don't wrap the chains, for the reasons LI Pets gave. They should simply be crossed.
Dave
Fyrzowt is offline   Reply With Quote
Old 09-30-2007, 11:08 AM   #13
I used ty-wraps to shorten mine. No twisting, no wraping.
Michelle TAC MT-0
Sarah, Snowball
Old 10-07-2007, 08:05 PM   #14
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
i better double check the location of my 'L' brackets... i don't have nearly as much torsion bar past the connection as what you're showing... i thought it was 29"-32" from the center line of ball to centerline of 'L' bracket... but I need to check installation manual...
boondockdad is offline   Reply With Quote
equalizer bars Bradjun1 Hitches, Couplers & Balls 1 06-07-2005 06:53 AM
Safety Chain Restraint Navigator On The Road... 3 02-28-2004 11:20 AM
Safety Chain Shaclkle - Weakest Link? Creampuff Hitches, Couplers & Balls 6 12-09-2003 07:46 PM
Equalizer bars...need one. boltos Hitches, Couplers & Balls 3 09-26-2003 10:21 AM
Safety chain femuse Hitches, Couplers & Balls 4 04-19-2003 09:26 AM
