Old 09-08-2011, 04:39 AM   #61
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Texas statute defines "safety chains" as:
(e) In this section, "safety chains" means flexible tension members connected from the front of a drawn vehicle to the rear of the drawing vehicle to maintain connection between the vehicles if the primary connecting system fails.
Old 09-08-2011, 06:18 AM   #62
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
True, but the statute also says that the administrative code defines the application of the statute. The code clearly specifies chains as a series of metal links as is posted above. I don't think you can pass inspection without chains.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 04-05-2013, 09:19 PM   #63
Vintage Kin
Fort Worth , Texas
btt
I didn't get around to changing things on that '83.
My latest "25-yr old TT" still needs new chains, hooks, attachments (have no idea about stress on current set of chains). Look okay, but . . . .
Old 04-05-2013, 10:55 PM   #64
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Texas law
(4) Safety chains must be attached to either side of the tongue or connecting apparatus of the towed vehicle, equidistant forward and aft of the hitch or connector. They shall not be directly welded to the towed vehicle, but rather shall be connected by means of bolts, pins, or other secure connecting methods, that meet necessary strength requirements
I guess Airstream missed this, my chains are both attached at one point in the center of the tongue.
Old 04-06-2013, 05:32 AM   #65
Vintage Kin
Fort Worth , Texas
And not attaching them to the hitch receiver, IIRC, as it may come off the TV.
Each chain must be of sufficient rating to handle the trailer is the other part.
Old 04-06-2013, 08:01 AM   #66
dkottum's Avatar
IIRC ?
doug k
Old 04-06-2013, 08:05 AM   #67
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Originally Posted by dkottum View Post
IIRC ?
doug k
If I Remember Correctly
Richard
Old 04-06-2013, 09:29 AM   #68
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
My chains were Airstream factory installed in June 2012 to what appears to be a piece of reebar welded to the frame just behind the ball socket. The trailer ends of the two chains are touching each other.
The only way I see to create a "cradle" would be to put a cross chain between the two lengths at a location that would catch the Hensley hitch or the stinger.
I wonder if a shackle and pin would work on the tow vehicle end since it would necessary to use one on the trailer end to install new chain. Safety wiring the pin would keep the chain attached.
Old 04-06-2013, 04:03 PM   #69
TinCan
graysailor's Avatar
2016 30' Classic
I would stick with chains.
graysailor is offline   Reply With Quote
Old 04-06-2013, 05:20 PM   #70
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I switched over to cables a few months ago and have never regretted it. Easy to use, strong, safe, secure and much cleaner than rusty old chains.
MICHAEL
Old 05-14-2013, 07:41 PM   #71
AWCHIEF's Avatar
Images: 33
Update on cables. I recently got back from a long trip. When I got back to the house and was unhooking I noticed that one of the cables had almost complety worn thru from it looked liked scraping the road. My bad for not noticing it sooner. I removed them and put the old rusty chains back on.
MICHAEL
Old 05-14-2013, 08:02 PM   #72
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Wouldn't that happen to chains too if they were dragging on the ground?
Old 05-14-2013, 08:19 PM   #73
AWCHIEF's Avatar
Images: 33
Yes, I would think so. I did say it was my fault for not keeping a better eye on them.
MICHAEL
Old 05-14-2013, 08:40 PM   #74
1976 31' Sovereign
Oswego , Illinois
Chains have more meat than cables I use only chains also pull heavy eqmt. would never use cables I feel chains are more reliable plus greater breaking point
Old 05-23-2013, 10:01 PM   #75
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Chains.. cross them over, if you feel you are going to 'drag' chains, use a rubber strap to hold the center of the chains higher.. works every time.. and if the chains are needed, the strap will hold them centered beneath the tongue of trailer..
Peace and Blessings..
Channing
WBCCI# 30676
LT versus ST tires on a trailer 91Excella Tires 18 08-29-2014 04:03 PM
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
RV safety education foundation 83Excella Link Archive 5 10-15-2004 05:44 PM
Trailer tire safety article 83Excella Tires 0 08-14-2002 08:44 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
