Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 09-07-2007, 11:39 AM   #1
myoung
myoung's Avatar
Goodyear , Arizona
Images: 24
Rubber bands for Equal-i-zer...
Many people complain about the loud popping sound or screeching that often accompanies low-speed turns with the Equal-i-zer hitch. I've found a simple solution that seems to work most of the time: rubber bands.
The source of the noise seems to be binding between the square bars and the L-shaped retaining pins. There is enough play in the pins to bend them when the bars move. The popping happens when the binding is released. That's my thinking.
So, the solution is to hold up the L-shaped retaining pins with a rubber band wrapped around the wire retaining pin ends and the big L-bracket on which the bars rest. In this way, the L-shaped retaining pins sit upright and are far less likely to bind, thus no noise.
Sorry I don't have a picture handy, but I hope this explanation is self-evident.
Mike Young & Rosemary Nelson
2006 Safari 25 FB LS
2005 Dodge Durango Limited 5.7L Hemi 4WD
Equal-i-zer hitch and Prodigy controller
http://web.mac.com/mikero1/
http://gallery.mac.com/mikero1
Four Corners Unit, Charter Member, WBCCI #2735
myoung is offline   Reply With Quote
Old 09-07-2007, 12:44 PM   #2
bradk
bradk's Avatar
Profile:  2006 19' International CCD
Calgary , Alberta
Images: 14
I think I see what you're saying but I'm not sure the bands would hold. Isn't that lateral play part of the way the friction sytem works?
brad (entirely NOT an engineer).
edit: re-reading your first post, you've gotten this to work already?
Team Ironcops for Cancer 2006
Raced! Ironman Canada in support of the Canadian Cancer Society
www.ironcopsforcancer.com
We raised over 1.3 Million dollars for Cancer Reseach this year. Great job team!!
bradk is offline   Reply With Quote
Old 09-07-2007, 06:08 PM   #3
myoung
myoung's Avatar
Goodyear , Arizona
Images: 24
The rubber bands just hold the L-shaped retaining pins upright. There is no pressure on the rubber bands. They just prevent or minimize or eliminate the binding between the retaining pins and the square weight-distribution/anti-sway bars.
This solution is far, far better than greasing the bars that has often been the suggested solution to the noise. IMHO, greasing the bars diminishes their usefulness as anti-sway devices and as such should not be done at all.
Old 09-07-2007, 07:48 PM   #4
lewster
Commercial Vendor
lewster's Avatar
Marco Island, FL , Hood River, OR
Mike,
If you talk to Equal-I-Zer tech support, they will tell you that greasing the bars has absolutely no effect on the sway control capabilities of the hitch, other than to reduce the noise.
I didn't think it would work either, but after I did lube the bars, I have not noticed any difference in the performance of the hitch.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 09-07-2007, 07:50 PM   #5
ckeysor
WBCCI 11067 WDCU
ckeysor's Avatar
Profile:  1986 25' Sovereign
Atlanta , Georgia
Talking
Thanks for the post. Such a cosmetic issue but it sure seems to bother people (Including folks riding in my car!). For us non-visual thinkers, is there any chance you could post a picture?
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 09-07-2007, 08:04 PM   #6
myoung
myoung's Avatar
Goodyear , Arizona
Images: 24
I doubt Tech Support personnel are engineers...
Originally Posted by lewster
Mike,
Part of the anti-sway capability of the Equal-i-zer hitch is doubtlessly due to the friction between the bars and the L-bracket supports. Greasing the bars here would/should reduce the capability. Perhaps Tech Support people are just trying to placate customers rather than trying to inform them.
Old 09-07-2007, 08:49 PM   #7
TIMEMACHINE
TIMEMACHINE's Avatar
Huntington Beach , California
Lube can work
Mike,
In some cases where there are parallel planes, "friction control" may actually be improved via proper viscosity lubricants. If binding is occuring, friction control has been lost and the effective dampning is reduced thus decreasing true control. The Tech's suggestion may have merrit.
Also, I believe that E-Q has recently made available some type of plastic composite plate that fits on top of the L brackect, under the sliding bar, to act the same as a lubricant with superior control with considerable noise abatement. I was planning on installing them before the next trip.
John
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 09-07-2007, 09:38 PM   #8
Relentless
Profile:  2007 25' Safari FB SE
Blaine , Washington
I have installed them. They are called Bracket Jackets. Takes about 5 seconds to install. They have no effect on sway control. They eliminate about 90% of the noise. They cost $17.95 plus shipping.
The sway control on this hitch comes from the movement, or lack thereof, of the ball hitch mechanism on the TV. Where the bars rest on the L brackets and distribute the weight, they can only slide back and forth. Side to side movement, which is sway, is controlled at the TV hitch mount.
John
"However beautiful the strategy, you should occasionally look at the results."
Winston Churchill.
Relentless is offline   Reply With Quote
Old 09-07-2007, 10:20 PM   #9
TBRich
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
We use the Bracket Jackets on our Equil-I-Zer bracket set up...they just slip over the bracket and sit between the bracket and the bars....like a cushion. We've always used them, as they were part of our original install... Easy to use, but they do break over time, so we ordered a set of spares to have on hand (along with a spare set of L-Pins and Cotter Pins just in case)...
TB
Old 09-08-2007, 08:06 AM   #10
cosmotini
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
This came from the Equalizer Hitch site.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Rivet Alert--trim bands Zeppelinium Ribs, Skins & Rivets 16 09-07-2007 08:26 AM
Rubber Gas Line Sundance LP Gas, Piping, Tanks & Regulators 4 07-13-2007 05:06 PM
June 1-4, Central NY Pageant of Bands robandzoe The Rally Zone 41 06-07-2006 07:33 AM
Pageant of Bands Rally June 4-6, 2005 robandzoe Forum Rallies 8 05-01-2005 06:30 PM
Door Rubber Scaler113 Doors & Locks 2 04-27-2004 01:22 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
