Old 10-24-2008, 07:39 AM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Right size WD hitch?????????
Ok, I borrowed my Friends 2004 Safari 28' for our last trip.... I fixed a lot of lose hinges, Shower door etc.. Stuff gets bounced around a bit... it seems...
He has a 3/4 ton Suburban and a regular Reese WD with 1000 lbs bars and a sway control bar. (I used this set up to tow it with my Sequoia)
My Question is: Are the bars too much? or is it normal for the newer hinges to start coming lose, Screws undoing?
He has had no rivet popping and they use it quit a bit...
Is this normal wear and tear? or are the 1000 lb bars to much for the 3/4 ton?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-24-2008, 08:13 AM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Jason
I personally think 1000lbs bars are to heavy for a 3/4 or 1 ton supension. I use 550 lb bars and I get the right (in my estimation) weights on the steering and drive and trailer. We also get the Lincoln like ride. We have wheelbase so that gives us ride also. Since I put new axles under the trailer we have none of that throwin around of things in the coach that we had before I made the axles change.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-24-2008, 08:33 AM   #3
SteveH's Avatar
Common Sense , Texas
I have always been told, and it is also my experience that the trunion (square) type bars which the Reese WD hitch uses, ride rougher than comparable weight round bars. That coupled with the heavy duty suspension of the 3/4 and 1 ton pickups that are so popular these days as tow vehicle, the 1000 pound bars are probably too heavy in those situations. In our father's times large sedans were "the norm" as tow vehicles, and the heavy weight bars with heavy trailers probably did fine.
Regards,
Steve
Old 10-24-2008, 08:33 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The 1,000 pound bars are way too much for the 'burb. More like 600 pound bars, maybe 750, would be more than enough.
Stiff suspension+stiff WD bars= stuff thrown around, loose fixtures and fittings, and eventual popped rivets.
Old 10-24-2008, 09:41 AM   #5
pintoman's Avatar
2015 25' FB Flying Cloud
Greensburg , Pennsylvania
I use Reese WD 550# bars.Seem to be just right.
pintoman is offline   Reply With Quote
What size Equal-i-zer Hitch Do You Use? SilverGate Community Polls 123 10-19-2013 06:03 PM
Hitch size Jim Sease Hitches, Couplers & Balls 16 10-12-2010 10:04 AM
Hitch ball size Argosy27 Hitches, Couplers & Balls 1 05-23-2006 05:53 PM
Ball hitch size schaumannk Hitches, Couplers & Balls 8 12-01-2004 07:31 AM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 04:56 PM
