Old 07-26-2016, 07:47 AM   #1
jamieb1086's Avatar
2016 25' Flying Cloud
Oradell , New Jersey
Removing sway bars for backing in
Hi all -
Newbie with a 2016 FC FB with an Equal-i-zer hitch. I'm wondering how many people remove their anti-sway bars before backing in. I was told this weekend that tight maneuvering with the bars on puts undo stress on the truck frame.
I haven't removed mine yet and while it does make some noise turning while backing in it seems to do ok with the bars on.
Is this good advice?
Jamie Bull
jamieb1086 is offline   Reply With Quote
Old 07-26-2016, 08:02 AM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Yes we do this, makes a difference when backing.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-26-2016, 08:09 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not necessary with the Andersen or Blue Ox systems. The only two systems I have actual experience with.
MICHAEL
Old 07-26-2016, 08:14 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I can't think of a reason to remove the BARS while backing up. That put no more strain on the frame than when going forward.
It has long been suggested that one loosen the EZ Sway Control Friction Plate before backing but not the WD bars.
2004 Excursion 4x4
Old 07-26-2016, 08:16 AM   #5
Gainesville , Florida
Used eazsway for years, never loosened them.
Old 07-26-2016, 08:16 AM   #6
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
I remove mine.
I have enough distractions without the "gunshot" going off at a critical time! Plus it's very common that I'm backing in past 9pm. I would hate to scare someone and make them drop their beer.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 07-26-2016, 08:19 AM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I have a typical friction type sway bar. I never take it off before backing.
CRH is offline   Reply With Quote
Old 07-26-2016, 08:29 AM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Never have taken my Equalizer bars off backing. Keeping the head sockets and ball lubed and bracket jackets is a quiet experience.
Kelvin
Old 07-26-2016, 08:41 AM   #9
aftermath's Avatar
Spokane , Washington
Originally Posted by kjritchie View Post
never have taken my equalizer bars off backing. Keeping the head sockets and ball lubed and bracket jackets is a quiet experience.
Kelvin
x 2
aftermath is offline   Reply With Quote
Old 07-26-2016, 08:48 AM   #10
mandolindave's Avatar
Slightly off topic.
My Rocket Scientist ( literally ) friend directed me into a spot at a rally type situation. The ground was a little mushy…then it rained.
To get out at the end of the event, I took off the sway bar and weight distribution bars. I wanted weight back on the rear wheels for more traction. I got out easily.
The Rocket Scientist said, " Humffff. That was a good idea !"
The moral of the story….Some Mandolin Players, ain't as dumb as they look.
mandolindave is offline   Reply With Quote
Old 07-26-2016, 08:50 AM   #11
1962 28' Ambassador
Mesa , Arizona
To clarify as the terms are often used interchangeably.
We remove or totally loosen our anti sway device not our weight distribution bars.
Sometimes if it's late at night the WD bars are a little creaky as far as noise and disturbing neighbors.
Hittenstiehl
Old 07-26-2016, 08:54 AM   #12
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
After reading some of the responses to the OP, I had to go back to be sure I read the post correctly and saw you were asking about the Sway device, not the WD torsion bars. It has been recommended by Can-Am to remove the Sway control device, but no need to remove weight distribution bars.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 07-26-2016, 09:38 AM   #13
2015 16' Sport
Portland , Oregon
My dealer told me to remove the bars but it's a PITA. So I called equalizer, and they said if it's set up properly (ie enough room left at the ends) you do not have to remove them. I have the pads under the bars at the trailer end that quiets all the noise. No problems backing
leedav is offline   Reply With Quote
Old 07-26-2016, 10:10 AM   #14
SeaLevel's Avatar
Jupiter , Florida
If I was backing up a hill into a site I might consider removing the bars, but so far I've never needed to and haven't had any problems.
SeaLevel is offline   Reply With Quote
Removing paper backing from vinyl floor? silverwoman Floor Finishes 1 10-13-2012 09:16 PM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
