Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 01-10-2008, 06:07 PM   #1
Profile:  2007 25' Safari FB SE
Truckee , California
Refined TV weight numbers = required weight distribution?
Well just for the fun of it i took my truck (F350 4X4 crew cab)to the dump so i could actually get the real weight currently on each axle. The results were 4,600 lb on front axle and 2,700 lb on rear axle (without camper). So then i called the camper mfgr to get center of gravity of camper/actual weight. He said that it was about 6" in front of rear axle. The camper will weigh 2,000 lb so i figure add most of it's weight to the rear axle. When you do that then you have 4,00 lb on front and 4,700 lb on rear axle pretty much balancing out truck axles. Now we add a 900+/- lb trailer tounge weight that is roughly 5' - 6" behind rear axle (fulcrum point) Looks like i really do need some weight distribution system when i travel with the camper on. Can one now figure how much needs to be transferred to front axle hence determine exact size of weight distribution system to place on trailer lb wise ?
Fred
flyfishfred is offline   Reply With Quote
Old 01-10-2008, 06:12 PM   #2
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Recommended WD bars would be 500#-750#. 500# is no longer available by most manufacturers, so the 750's would have to do. I use 750's on our 7000# trailer, 800# tongue weight, and a 3/4 ton truck with a camper shell on the back.
You repair things with tools. You fix things with a hammer.
AIR#2611
overlander63 is online now   Reply With Quote
Old 01-10-2008, 08:23 PM   #3
Smile
Hi Terry,
Well your camper shell does not weigh 2,000 lb , correct ? its probably quite lighter.
Just got off the phone with my niece's husband who is a structural engineer. We discussed the weight numbers and here is what he came up with.
The truck without the camper is actually quite balanced weight wise with only the trailer on it ( roughly 4,600 lb on each axle) thereby really not needing weight distribution.The same thing is true (balanced ) with just the camper. When combined ( camper along with the trailer ) it actually adds 1,247 lb more to the rear axle and subtracts 347 lb off the front axle (fulcrum effect). In order to balance the trucks axles weight equally,then what is required is to shift approx 800lbs up to the front axle (tires) through a weight distribution system. I think thats correct.
Fred
Old 01-12-2008, 07:52 PM   #4
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Weight Distribution?
Perform the Acid Test.
At first chance with the trailer on the TV, stop at a truck stop that has a CAT Scale (Certified Automatic Truck Scale).
The first pass here in VA is $10.00 and every pass there after for the next 24 hours is $1.00.
No amount of calculator will be more accurate than actually getting the thing weighed.
Also
What do have in the way of anti-sway device.
Beginner
Beginner is offline   Reply With Quote
Old 01-12-2008, 08:13 PM   #5
Images: 52
Originally Posted by flyfishfred
Hi Terry,
Fred
Correct. But I bet you don't have a toolbox and tools totaling 1300 pounds in the back of your truck. So, the 200 pound camper shell, and the 1300 pounds of tools, add up to 1500 pounds.
AIR#2611
Pingbacks are On
Weight distribution set-up Ball_Park145 Hitches 32 06-14-2007 07:13 PM
Weight Distribution and Sway kl8ton 1973 Sovereign 12 07-31-2005 06:32 PM
please explain Weight Distribution pinkflamingoes Hitches 13 05-30-2004 01:55 PM
Weight Distribution newae On The Road... 9 07-18-2003 10:08 PM
weight distribution Craig Hitches 2 04-14-2003 06:57 PM
SEO by vBSEO 3.1.0
