Old 10-22-2010, 07:44 AM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Reese Weight Distribution - RP66151
Researching a Reese weight distribution system for the 1955 Safari and looking for feedback on the below system.............thanks toastie
Reese SC Weight Distribution System w Sway Control - Trunnion - 10,000 lbs GTW, 600 lbs TW Reese Weight Distribution RP66151
ID:	113768   Click image for larger version
toastie is offline   Reply With Quote
Old 10-22-2010, 08:27 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
How heavy is that trailer, and what is the tow vehicle?
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 10-22-2010, 09:00 AM   #3
toastie's Avatar
1955 22' Safari
- Bart
TV is a 2008 Cheve Trailblazer, gross vehicle weight rating 5,550 lbs, curb weight 4,356 lbs. with max towing capacity is 5400 lbs. The trailer approx weight is 2800 lbs tw 275 lbs.
Old 10-23-2010, 01:11 AM   #4
Maniacal Engineer
barts's Avatar
From the ratings, this will work. I don't really know how "springy" the bars are though; your trailer tongue weight is pretty low - you don't want really stiff bars, as they make the ride more rigid.
Your best bet is to find someone that uses a similar setup... most folks seem to prefer the twin-cam units like this one.
I don't use a WD hitch w/ our 3/4 ton truck, but folks around here tell me I'm doing it wrong .
- Bart
Bart Smaalders
Menlo Park, CA
Old 10-25-2010, 09:10 PM   #5
SteveH's Avatar
Common Sense , Texas
toastie,
That particular Reese hitch works like any other weight distributing hitch, and as far as sway control is concerned, works on friction like the Equalizer hitch, and so depends on tongue weight. It would not work well in the anti-sway department with a trailer of low tongue weight, as I understand it. I've not used one, but it is an interesting concept and deviation from Reese's usual aproach to sway control.
Regards,
Steve
Weight distribution hitches Reese Pullrite Equal-I-zer Blue Ox Hensley Air Ride markdoane Hitches, Couplers & Balls 2 09-04-2014 08:57 AM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Weight distribution - I still don't get it WK57ABF Hitches, Couplers & Balls 46 05-18-2009 04:24 PM
Reese Trunion Type Weight Distribution Set Up mtjim Hitches, Couplers & Balls 18 09-29-2008 01:27 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
