Old 09-10-2016, 08:01 AM   #1
2014 30' FB FC Bunk
Annapolis , Maryland
Reese WD Hitch Shank Drop
I am currently set up to tow a 2014 FC/FB 30' with a 2013 Yukon XL/2500/6.0L. The receiver on the Yukon XL is 3 1/2" higher than my planned replacement tow vehicle. I am intending to merely replace the shank with one that has a shorter drop to accommodate the difference.
Seems like a simple solution but would like to know if there is anything I missed in this assessment -- seems too easy.
w/r Zane
rhassm is offline   Reply With Quote
Old 09-10-2016, 08:13 AM   #2
1977 31' Sovereign
2005 30' Safari
North Port , Florida
When my parents changed vehicles, we used the same shank and cut off the excess after setting everything back up. That was going from a Suburban to Dodge 2500. Just another option to think about.
cliffcharb is offline   Reply With Quote
Old 09-10-2016, 08:44 AM   #3
1976 31' Sovereign
Oswego , Illinois
If the shank is bolted into back of head as mine is, why not turn shank over will get drop of head?
Old 09-10-2016, 08:52 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
w/r Zane
That's pretty much what you've got to do, not complicated.
Bob Martel
WBCCI# 5766
Old 09-10-2016, 08:35 PM   #5
1988 32' Excella
Robbinsville , New Jersey
The only thing you need to keep in mind is you need to worry about the loaded height not the empty height. A 1/2 ton might drop an inch more then a 3/4 ton or if a vehicle has load leveling it might not drop at all.
Reese 3344 drop shank outdoors717 Hitches, Couplers & Balls 3 04-04-2016 05:31 PM
Combining 4" drop reciever to Hensley 8" drop shank Rascal0729 Hitches, Couplers & Balls 18 07-20-2015 06:52 AM
Deep drop WD hitch shank ground clearance? mountainboy Hitches, Couplers & Balls 5 07-20-2009 05:56 AM
Shank too long for Reese Hitch? Bakes5 Hitches, Couplers & Balls 8 04-19-2007 07:57 PM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 01:30 PM
