Old 11-09-2014, 07:02 PM   #21
Originally Posted by Keith Gantt View Post
Still using my 1200 lb bars from my old SOB, a little over kill for our 23fc but with set up procedures followed I Have no complaints.Attachment 226146
The Streaming Gantt's on Airstream Forums
The best test to determine the correct Reese bar rating is very simple.
The bars should bend an absolute minimum of 1 to 1 1/2 inches.
The greater the bend, to a point, the greater the sway control.
My Reese bars bent 3 inches. I could tow all day long with 2 fingers on the steering wheel.
Reese bars are tested to a 5 (five) inch bend. If the bar does not completely straighten out when the pressure is released, the bar is rejected. I watched them do those tests.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-09-2014, 09:40 PM   #22
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I probably don't have my bars tight enough from what I'm reading. I'm going to tighten them up a link & try running without the sway bar. It was from a set up I had on another trailer that was an EZ lift system. I'm really not sure if it is compatible with the Reese WD bars I have. I am down in Destin, FL and seriously considered getting a propride from a guy not too far away, but don't have anyone to install it for me. I towed this trailer before without the sway bar without issue. It seems that that is the only different variable in the mix. If things get dicey, I can always stop & throw it on.
Sent from my iPhone using Airstream Forumsy
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-09-2014, 09:58 PM   #23
2007 22' International CCD
ProPride can be installed by a 60+ old fart and 18 year old daughter, assuming you have the manual and the right tools. Only hard part is lifting the bigger bits into position under the tongue. It's not too hard...
Old 11-09-2014, 10:10 PM   #24
Becky B.'s Avatar
1964 17' Bambi II
You don't understand that I'm 900 miles from my tools that would be needed for installation. I'm a pretty capable woman, but I'm not willing to install something that connects my TV to my trailer (with my sister following behind me) without the over site of someone who is more knowledgeable about their installation than I am ( which is a big fat goose egg).
Becky
1964 Bambi II
1988 Avion 32S
Old 11-09-2014, 10:44 PM   #25
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Fwiw, when I was towing on the ball I never had sway events below about 62 MPH.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-10-2014, 12:19 AM   #26
Ah, understand being separated from tools is the issue. Consider getting the ProPride if you can at a decent price...it should tow a lot better when you can get it installed.
Old 11-10-2014, 06:03 AM   #27
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Originally Posted by beckybillrae View Post
I have Reese wd bars on my 30' Avion. Should I also have a sway control bar? I have one & the trailer has a ball mounted to it, but I'm not sure if it works against the wd bars. I'm down in Florida & had some pretty bad sway episodes on my way down & used the sway bar. Wonder if I should go up a notch on the wd chain & skip the sway bar. Not excited about my 900 mile trip home!!
First of all, do you know what model Reese hitch you have? If you have the Dual Cam, or the Straight Line, I agree with Andy, you need to increase tension on the bars.
If yours is a Reese weight distribution hitch only, you need to buy the addition sway control parts that go on the trailer tougue. Make sure your bars are not too heavy for your trailer. I would think 800# bars would be right for your Avion...
If there's any chance you are in northern Florida, we live about 20 miles west of Pensacola, I would be glad to help.
Larry
Larry C is offline   Reply With Quote
Old 11-10-2014, 06:56 AM   #28
Did you ever ride in the back end of your Airstream when it's being towed?
Try it at even 50 mph, and watch what happens.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-10-2014, 07:43 AM   #29
Becky B.'s Avatar
1964 17' Bambi II
Name:	ImageUploadedByAirstream Forums1415630489.602576.jpg
This is my set up. I pulled it up one link & now need to adjust the saddle. If I take it up 2 links, it's REALLY taught.
Becky
1964 Bambi II
1988 Avion 32S
Old 11-10-2014, 07:44 AM   #30
Becky B.'s Avatar
1964 17' Bambi II
Reese wd bars
Thanks, Larry, for the offer. I'm pretty Far East of you, on the east side of Destin. I'm sure I can handle the adjustments.
Becky
1964 Bambi II
1988 Avion 32S
Old 11-10-2014, 07:48 AM   #31
Attachment 226173
Try it at three links.
Your Reese has a very good sway control.
It would appear that it's never been adjusted properly, which caused the addition of the "friction sway control".
Try the three links and remove the friction sway control, and then take a short trip with the trailer.
I think you will be very pleased with the results.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-10-2014, 07:52 AM   #32
Someone also changed the coupler.
You may have to change the angle of the ball mount, so that the Reese bars stay parallel to the frame.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-10-2014, 07:56 AM   #33
Becky B.'s Avatar
1964 17' Bambi II
Name:	ImageUploadedByAirstream Forums1415631365.911956.jpg
ID:	226175this is 2 links up.
Becky
1964 Bambi II
1988 Avion 32S
Old 11-10-2014, 10:00 AM   #34
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Attachment 226175this is 2 links up.
Please take a picture looking straight on from the side so we can see how much the bar bends - it's hard to tell from that angle of picture.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-10-2014, 11:10 AM   #35
Becky B.'s Avatar
1964 17' Bambi II
Well, things have taken a turn. As I was struggling to remove the rusted nuts off the brackets to move them forward, I got a call from the gentleman with the propride. He found a local rv repair place that will come to my campsite & install the propride. I'm off to meet the kind retired Naval officer & buy his 3 month old propride. Having it installed tomorrow. Going home with less anxiety Wednesday.. I'll take a picture of it installed. Merry Christmas to me😁
Becky
1964 Bambi II
1988 Avion 32S
Old 11-10-2014, 11:21 AM   #36
HowieE's Avatar
Princeton , New Jersey
Images: 12
Looking at your picture it appears you have hit the yoke and marked it with the bar. This is a common problem with the Straight Line system. This happens to the outside bar while in a sharp turn while backing up. Consider grinding off about 1/8 in. of material at the point of contact. If not you may bend the yoke.
2004 Excursion 4x4
Old 11-10-2014, 11:26 AM   #37
Fine business on the ProPride. Any issues call Sean direct and he will respond quickly. Make sure the yoke is dead center under the A frame when installed and it will tow beautifully!
Old 11-14-2014, 04:32 PM   #38
Becky B.'s Avatar
1964 17' Bambi II
Made the 900 plus mile trip home to freezing cold temps:-(. The great news is that I had zero sway incidents and all of my precious cargo (daughters & grandbabies) arrived home safely. PRICELESS! My wallet is a lot lighter....maybe the lighter load had something to do with it! Click image for larger version
Name:	ImageUploadedByAirstream Forums1416007911.663352.jpg
Becky
1964 Bambi II
1988 Avion 32S
Old 11-14-2014, 05:05 PM   #39
Glad it all worked out. Enjoy the lack of white knuckle ride!
How Are Reese Weight Distribution Bars Rated? Eagle & Bear Hitches, Couplers & Balls 3 04-14-2012 06:58 PM
Reese 600 lb. bars discontinued--is it true? mimiandrews Hitches, Couplers & Balls 14 06-25-2011 09:19 AM
Size of 600lb Reese Trunnion bars? glacierrunne Hitches, Couplers & Balls 5 08-09-2010 08:07 PM
Reese Dual Cam Trunnion Bars dscluchfc Hitches, Couplers & Balls 17 04-21-2005 05:52 AM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
