Old 03-26-2012, 12:23 PM   #1
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Reese U-Bolt Torque?
I have added a third u-bolt to my old-style Reese cam arms. I think I remember the torque spec on the u-bolts is 75 ft-lbs. Does anyone know for sure the torque spec?
Thank you in advance.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 03-26-2012, 03:51 PM   #2
2002 25' Safari
Images: 11
I found the torque spec in a Reese document from a general web search. The torque spec is 60 ft-lbs.
http://triadtrailers.com/wp-content/...y_.control.pdf
Bud
Old 06-20-2012, 07:06 PM   #3
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Does anyone know where to purchase replacement U-bolts? I need 2 of them
surfpod is offline   Reply With Quote
Old 06-20-2012, 07:49 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings surfpod!
The easiest method that I am aware of is to source them from any shop selling Reese hitch products. Most Vintage Airstreams need what is sold as U-bolts for 4" and 5" frames . . . these usually need to be ordered as I have yet to find a dealer other than one who does business with Vintage Airstream owners that actually stocks anything other than the larger U-bolts that are utilized on Brand-X as well as late model Airstreams. I keep an extra set of 4 in my parts kit as I generally replace them every time that I repaint the hitch on either of my coaches.
Good luck with your investigation!
Kevin
P.S.: This link has the U-bolts that I utilize with my Vintage Airstream and Argosy . . . Link.
Kevin D. Allen
AIR #827
Old 06-21-2012, 06:31 AM   #5
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Kevin, thanks very much for your help!
Old 06-21-2012, 08:02 AM   #6
Properly stressed Reese torsion bars, used with the dual cam sway control, will cause the U-bolts to stretch in time.
The solution is easy.
Adding a third u-bolt will correct any further stretching of the u-bolts.
When the u-bolts stretch, the sway control will be loose leading to inadequate sway control.
That has been an issue for over 40 years, to my knowledge.
Proper torque for lug nuts. ole-red Off Topic Forum 9 05-31-2014 08:58 AM
filling cracks and bolt indents goshawks00 Floor Finishes 8 03-09-2012 08:31 AM
Bolt pattern & tire size for 68' Ambassador silverwoman Wheels, Hubs & Bearings 3 02-16-2012 09:36 PM
About to Recycle my Reese Dual Cam thecatsandi Hitches, Couplers & Balls 11 11-30-2011 07:31 PM
T Bolt - Where can I get some? MrJ Mechanics Corner - Engines, Transmission & More... 3 11-17-2011 06:38 PM
