Old 08-08-2015, 02:41 PM   #1
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Reese Trunnion and ball slipping
I have an older Reese trunnion that I cannot get the washers with teeth to keep the ball tilt at the angle I want.
I am using 2 of the washers with teeth on each side of the trunnion and am torquing to 300 lbs, both the top bolt and the bottom bolt. With the tilt the way I want it, the coupler is about 1 inch from the shank (not shown).
But within moments of pulling the Airstream, the ball has slipped and tilted back up, the washers have slipped, and the coupler is once again touching the shank. (see photos)
I suspect it is a combination of the trunnion is worn out where the slots on the washers are supposed to connect, along with the pressure the trunnion bars place on the top bolt and washers.
Any suggestions? Do I need to buy a new trunnion?
ID:	244952   Click image for larger version
JBBeaubeaux is offline   Reply With Quote
Old 08-08-2015, 02:48 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
The new trunnion design eliminates the problem. Haven't looked at the price since I bought ours several years ago. It's worth considering.
Old 08-08-2015, 02:59 PM   #3
1981 31' Excella II
New Market , Alabama
Looks to me like the bolts are too small in diameter. What is the actual diameter of the holes? Mine is an older version of that hitch and it does not slip.
Perry
Old 08-08-2015, 03:15 PM   #4
2001 30' Excella
The bolts are what Reese said to use. " #8
Old 08-08-2015, 03:29 PM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Looks like the no slip washers are worn out, are you tightening the bolts with an air wrench?
Old 08-08-2015, 04:01 PM   #6
2001 30' Excella
They are very old washers. You think maybe replacing them with new ones will solve my problem?
I have been taking the truck to a auto repair shop and they have been sing their equipment to set the torque at 300 lbs.
Old 08-08-2015, 05:10 PM   #7
1981 31' Excella II
New washers would help and bigger bolts preferably with a non-threaded upper shank.
Perry
Old 08-09-2015, 06:57 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The bottom washers look like they are soft steel, you need hard steel washers on the bottom and new ones on top. You could weld it in the correct location..
Old 08-09-2015, 07:32 AM   #9
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
If it is like the one I have, what keeps it tilted is the amount of center washers used below the ball and then you tighten the center bottom bolt to keep the washers secure.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 08-09-2015, 07:56 AM   #10
dznf0g's Avatar
Oswego , Illinois
Take a pic of the face of the trunnion and ball mount from the rear (between the spring bars. It appears to me you are missing the tilt pin, washers and tightening bolt for the tilt adjustment. They are what hold the head in the proper position, not the bolts themselves.
-Rich-
Old 08-09-2015, 10:57 AM   #11
2009 16' DWR
Lake Arrowhead , California
Shim
I had the same problem one time and fixed it by making a shim out of flat stock steel. I took a piece of steel the width of the opening between the ball mount and body and put a bend in it facing the ball so it would not slip down when slid into place. That did the trick. You have a tremendous amount of torque pushing in on the mount for bolts and washers to hold alone.
Hope this helps...
AS Mikey is offline   Reply With Quote
Old 08-09-2015, 11:00 AM   #12
1977 31' Sovereign
Lynnwood , Washington
This hitch design gives you lots of flexibility. But sooner or later, Achilles Heel (design weakness in your hitch) will show itself.
Solution, get hitch height where you want it and then weld it.
Tom
TomKirk is offline   Reply With Quote
Old 08-11-2015, 07:15 PM   #13
2001 30' Excella
Bought a new Reese Trunnion
After everyone's comments and a little research, I bought a new Reese Trunnion to replace the old worn out one.
It should arrive in a few days and solve my problem.
Thanks for all the advice.
Old 08-11-2015, 08:05 PM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Very good idea....
Reese Dual Cam Sway Control for round/trunnion hitches rogerdodger Hitches, Couplers & Balls 18 08-04-2009 08:46 AM
Tranny guru's out there? OD slipping? 3Ms75Argosy Tow Vehicles 15 04-23-2009 07:31 PM
Slipping Fridge Panel ESCAPE POD Refrigerators 2 12-14-2007 11:18 AM
Reese round bar or trunnion? erock53 Hitches, Couplers & Balls 21 05-09-2007 10:28 PM
Reese Dual Cam Trunnion Bars dscluchfc Hitches, Couplers & Balls 17 04-21-2005 05:52 AM
