Old 09-26-2008, 08:30 AM   #1
mtjim's Avatar
1973 25' Tradewind
New Bloomfield , Missouri
Reese Trunion Type Weight Distribution Set Up
Need a picture of a properly Reese Trunion type Weight Distribution set up on an Airstream.
I recently bought the airstream and it came with the WD. The ball hitch was too high for my TV so I have had to buy a new adjustable Ball hitch.
When I Measure my ball height at the lowest setting it's a little over 19" At the next setting up it's a little over 20". After I got the WD system hooked up at the lower setting the truck looks level but the trailer is about two inches lower at the front than at the back. Should I got to the next setting up or what?
Any suggestions?
mtjim is offline   Reply With Quote
Old 09-26-2008, 08:32 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Send us a picture of your set up......
Michelle TAC MT-0
Sarah, Snowball
Old 09-26-2008, 08:37 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A picture would help. I would raise the hitch one inch and see what it looks like. When everything is adjusted correctly the trailer and the truck should both be level.
Richard
Old 09-26-2008, 08:43 AM   #4
mtjim's Avatar
1973 25' Tradewind
Here the picture. Sorry the camera is not any better.
Old 09-26-2008, 09:01 AM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
The first thing I see from your picture is that you do not have any bend in your arms. I have basically the same setup and with mine adjusted correctly I attach the 5th chain link to the trailer. You need to have about an inch of bend in the bars for them to work correctly. Take a look at the file I am attaching. It goes step by step through all of the adjustments. You may need to do this several times to get everything correct. Height of the ball, angle of the ball and deflection of the bars all need to be considered.
Richard
Old 09-26-2008, 11:28 AM   #6
Keymar , Maryland
Now take one of the entire truck and trailer directly back from the ball.
Michelle TAC MT-0
Sarah, Snowball
Old 09-27-2008, 05:45 AM   #7
mtjim's Avatar
1973 25' Tradewind
Ok here's the entire rig.
Disregard the bumper angle - the receiver hitch is not connected to the bumper in any way but rather to the frame like it's supposed to be.
Old 09-27-2008, 08:34 AM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
As noted above it looks like you have No weight transferred by the fact that the bars have no deflection in them.
Set up the system again with these considerations.
Make sure you are on a level pavement for both TV and trailer combination.
Drive onto the pavement while towing the trailer straight for at least 75 ft.
Use the trailer brakes to stop the combination, this insure things are straight.
Disconnect the trailer.
Measure the height of both truck fenders right up through the center line of the wheels. It help to put a piece of masking tape on the fender and marking the measurement point on the tape. Record the measurements.
Hitch up and measure the fender heights again. Both measurements should drop. Generally I look for a 60 40 ratio with the rear fender dropping more than the front fender. This will depend on spring ratios of the truck put the important consideration is you want to see a drop in the front fender.
If adjustments are required either take up a chain link and remeasure or tilt the head back and remeasure.
If things do not fall into place, and you would have to be very lucky for that to happen, make adjustments. This is not a 5 min. job so don't start this in the sun.
When done you want the trailer tongue higher than the rear and weight on the front axle of the truck. The reason I mention the height of the trailer tongue as being higher is with the Airstream axles not being self equalizing you want to insure you are not reducing the tongue weight by having shifted weight to the rear of the trailer.
If after you have completed the set up and you find you have trailer sway you should consider getting a duel cam sway control system. If you do install a duel cam system the set up is much the same except that when finished you have to be sure the trailing arms are seated while the combination is straight. This may require reentry onto the pavement and checking things again because misaligned cams will change the WD effects of the system.
2004 Excursion 4x4
Old 09-27-2008, 08:36 AM   #9
From your photo, I see two things that are very "unhealthy."
The first is you should use a sway control. Your truck has "no" magic that can keep you out of a sway.
Secondly, it looks like the rear springs of the truck have been jacked up. That totally defeats the purpose of a load equalizing hitch.
Old 09-28-2008, 06:11 AM   #10
mtjim's Avatar
1973 25' Tradewind
Andy,
Thanks for your comments.
I just didn't have the sway bar installed when I took the pictures. As to the truck having been jacked up - it's just like it came from the factory.
Old 09-28-2008, 06:58 AM   #11
Andy,
Without a good description of what truck you have, it appears from your photo that the load level torsion arms are useless, because of the excessive suspension rate on the truck.
Old 09-28-2008, 10:00 AM   #12
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
The way I got around a too high hitch (22" in) was purchase a BLUE OX 4" drop and inserted in the receiver and then inserted the hitch. I don't need it any more since I put new axles under the trailer and raised it 4'" Ill ship it to ya.
Roger
Mikethefixit is offline   Reply With Quote
Old 09-28-2008, 06:00 PM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Based on the pic and the rear axle hub and the exhaust pipe tips
This is a pre-1997 Ford F250 4X4, likely a heavy 3/4 ton with a big block gas engine, 460 I am guessing. It would have rear anti-lock brakes as standard and the rear end has not been lifted. It was designed to handle big loads. Huge loads.
>>>>>>>>>>>>>>Action
Old 09-29-2008, 04:58 AM   #14
mtjim's Avatar
1973 25' Tradewind
Roger
I appreciate the offer but I think I'm gonna be allright when I get this one adjusted. I've got some time today to work on it so am anticipating that it's all gonna shape up today.
Again Thanks for the generous offer!
Reese Dual Cam Set Up... norsea Hitches, Couplers & Balls 327 07-05-2016 11:33 AM
Weight distribution hitches Reese Pullrite Equal-I-zer Blue Ox Hensley Air Ride markdoane Hitches, Couplers & Balls 2 09-04-2014 08:57 AM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Weight distribution set-up Ball_Park145 Hitches, Couplers & Balls 32 06-14-2007 07:13 PM
Weight Distribution newae On The Road... 9 07-18-2003 10:08 PM
