Old 09-22-2003, 08:41 PM   #1
dlorahcof's Avatar
Question Reese Strait-Line install
Has anyone installed the Reese DC Strait Line.
The pictures look like the sway backets are bolted through the
trailer frame.
Does this compromise the frame strength or is it better to use
U-bolts on a different DC.
Does the tank mounts interfere with the U-bolts?
Kinda in a stew over this one.
thanks
dlorahcof is offline   Reply With Quote
Old 09-22-2003, 08:54 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I installed the Reese...
....U-bolt type on my 78 Tradewind. I was glad it worked, as that was the only hitch setup I had, and I was 900 miles away from home!
I found that I could lift the tanks and slide the u-bolts under, no problem. I even had the hitch and the bars set up to the correct dimensions (per the Reese instructions at http://www.reeseproducts.com/support...fs/66006IN.pdf ) before I got there, and astonishingly enough, no adjustments were needed in the field.
I just happened to purchase this one, as the local RV Salvage yard had it used, but I am very happy with it...
Don
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Reese vs. Equal-i-zer joshua32064 Hitches, Couplers & Balls 11 10-25-2003 07:44 PM
gas line to water heater bken Water Heaters, Filters & Pumps 0 05-03-2003 08:11 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
