Old 05-13-2005, 05:50 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Reese Straight Line Install
Hello, The install sheet says to drill holes for the frame plate 18" from the center hitch ball socket. I read on another forum that this measurement is not correct. Would appreciate any info from anyone who has installed these? Thanks Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-13-2005, 07:42 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Marvin,
When we did the install on Vintage thunder that was the measurement we used. The distance to the saddles can be "tuned" using the threaded turnbuckles. If Reese says 18 inches in the printed instructions I would go with that. They have a reason for recommending that as the correct distance based on engineering. If there were newer instructions I would assume that they would be on the Reese site
http://www.reeseprod.com/support/sup...dfs/N26002.pdf
Link to PDF of the instructions
The 18 inches is to the top pivot point on the sway control. The installation orientation of the bracket makes no difference, it is purely a matter of having mounting options. Please review the instructions, and I bet you will find that the other installer was not measuring to the pivot point. I had to read the instructions 3 times before I drilled holes on VT.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
Reese Electra Lift Road Ruler Jacks, Stabilizers, Lifting and Leveling 0 08-22-2002 04:12 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
