08-23-2017, 06:20 AM
2013 25' FB Flying Cloud
Danville
, Indiana
Reese Steadi-Flex WD Hitch
I've learned that Reese has come out with a new WD hitch called the Steadi-Flex. As a long-time (and satisfied) Reese Dual-Cam user, I'm interested in knowing how the new Reese design compares in use to the traditional dual-cam model. Any information is appreciated.
Don
08-23-2017, 06:28 AM
Oswego
It appears it will work much more like an equalizer, but with tapered bars, I suspect it will have much more flexibility. My observation is solely based upon looking at pictures.
-Rich-
08-25-2017, 09:15 AM
Danville
, Indiana
Dznf0g, thanks for the comment. I guess I'll have to wait to learn more until the Steadi-Flex becomes more commonly used.
Don
08-25-2017, 10:01 AM
Sag Harbor
, New York
08-25-2017, 10:16 AM
Tampa
Looks interesting.
They definitely copied the good features of the Equalizer, and added more flex. Then simplified the head.
08-25-2017, 11:41 AM
I like that the head doesn't appear to be as tall as the dual cam. I usually drag the bottom of the hitch head/shank going in an out of my driveway.
I don't like that the sway bars need to be pinned into the head and then secured with spring clips under the head. At my age getting down on a knee to find the hole for the spring clip is hard.
Also I wonder how quickly the holes for the pins that hold the sway bars will become wallowed out.
08-25-2017, 11:50 AM
Sag Harbor
, New York
Copy that! My first thought when I saw that photo . . .
08-25-2017, 11:51 AM
2007 30' Classic S/O
Somewhere
, South Carolina
I agree in concept about using friction material at the bar to bracket joint rather than steel on steel. Just needs the right properties.
08-27-2017, 06:03 PM
Vintage Kin
Fort Worth
(My latest pants feature an interior insert pocket for an accessory custom neoprene knee pad. Bought six of them, ha! And shoe laces are sooo Twen-Cen)
08-27-2017, 07:25 PM
Tampa
Equalizer now sells a pad that the bars ride on also. Looks kind of plastic, rather than brake pad, but folks say the difference is less noise.
08-28-2017, 06:41 AM
Somewhere
, South Carolina
Have them on mine for several years now.
