Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 09-15-2009, 11:55 AM   #1
Profile:  1968 24' Tradewind
Oxford, , Mississippi
Reese sc vs equalizer wd hitch
Wondering if anyone can compare pros and cons of the Reese SC vs the Equalizer WD hitches. I am leaning toward the Equalizer but the Reese looks good too.
Thanks.
68 TWind is online now   Reply With Quote
Old 09-15-2009, 04:28 PM   #2
Profile:  2010 27' FB Flying Cloud
Montreal , Quebec
Send a message via Skype™ to Rawn77
My Experiences
First off, let me preface my remark here to tell you that I do not have an Airstream. (I do own a 27' Pilgrim travel trailer, my TV is a Mercedes ML320 BlueTech Diesel). I first found out about this forum while Google-ing some RV questions.
After doing much research (but not enough!) I purchased the Reese SC after considering the Equalizer as well. Was it good or bad? Since it was my first towing experience, I had nothing to compare it to. It was what it was...
Several months later after doing more research; and feeling a little bit dissatisfied with my towing experience (I thought for sure it was my TV); I consulted this and other forums to help shine some light on my dilemma.
I'm sure like most of the readers here, you're probably convinced of one thing; the bigger the TV; the better. If a 1/2 ton won't do, get a 3/4 ton and so on..... Just throw some mass at the trailer; that’ll calm her down.
So with my new gathered knowledge I was seriously looking at a new Ford F-150 to tow my TT. But literally 2 days before I was going to make my new Ford purchase, I stumbled upon a few forum entries from Andrew T at Can-Am RV and decided to give him a call (Can-Am is an 8 hour drive from my house). This man; Andrew, has a whole different take on TV's and hitches compared to the vast majority of what is written in this and other forums.
After speaking to him for about 30 minutes on the phone, I was convinced that my towing woes were not caused by the 'small' stature of my TV but by the typical hitch setup and subsequent installation method used by my RV dealer.
The following weekend I made my way over to Can-Am in London, Ontario for my makeover. They removed (threw away) my WD assembly and installed a custom welded ball-mount/shank so that the hitch is as close to the rear bumper as possible. The ball-mount is now tilted downwards. Then, they installed an Eazy-Lift WD hitch featuring tapered round bars. Because of the ball-mount angle, the torsion bars are angled as well towards the ground, which really allows them to be torqued up (pulled upon) therefore forcing the front of my TV down. (As a side note, Andrew reinforced my factory hitch so to really be able to take that downwards force). After all was said and done, the rear of my TV was down 1/2" and the front was down a 1/2"; the TT is now perfectly level!
Andrew wanted to take me out for a test drive with the new setup and he drove first; I sat in the passenger seat. We were going down a deserted stretch of road not far from the dealership going about 50 mph. Without warning he changed lanes in a fraction of a second. I thought to myself, OMG, I'm gonna die. You don't jerk a TV pulling a 3 ton TT like that; surely we'll end up on our side in a ditch. After making a 1/2 second prayer to the almighty, he did it again; emergency lane change maneuver!!
To my amazement we were still intact, going 50 down the road. WOW!!
"I just wanted to feel the overall balance"; he said; "Feels good to me!"
He pulled over and let me have a try. What a freakin difference! My Mercedes is handling awesome! I don't need a pickup truck. This is crazy!
Since then I have towed about 5000 miles; loving every minute of it. I’m not saying this is good for everyone; well that would be politically incorrect….right? Sometimes the solution is not to overwhelm the TT with a bigger/heavier TV but to hook them up properly.
We’ve all seen the unbalanced setups rolling down the highway; the TT pointing down at the hitch while the TV’s rear sits on the floor and its front sitting high up in the air. You can just imagine the driver’s white-sweaty knuckles gripped tightly on the steering wheel. There’s a better way. Now I can understand why Can-Am sets up Jaguars, mini-vans and Dodge Chargers to pull 34’ Airstreams. Because they can, and they do it well.
I do not work or am in any way affiliated with Can-Am RV; just a really happy customer spreading the word.
So to answer your question, boy can I ramble, I would stay clear of the Equalizer or the Reese SC. Get a good Round Bar (Tapered) and install it right. Maybe ask your dealer to send one of their technicians to Can-Am for a class. Or better yet, take a trip to London, ON and let Andrew set it up for you. It’s worth it!
It’s time to change the notions of towing out there. Just think, if more folks thought they could tow with their existing vehicles, the RV industry would sell more RV’s. That’s a good thing; no?
OK; let me have it guys. I can take it…….
Just one happy RV’er,
Ron Feinberg
Rawn77 is offline   Reply With Quote
Old 09-15-2009, 04:43 PM   #3
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
Thanks.
The Reese SC, to my knowledge, is fairly new, and so you probably won't find many with experience using it. Both hitches (Reese SC and the Equalizer) use the same basic principle for sway control, friction. However, the Equalizer has four points of friction, the Reese SC two. But, the Reese has the brake material for a friction point, the Equalizer metal to metal.
I have the Reese Dual Cam, and once it is adjusted correctly, it works really good. But, and there's alway a "but", it's a real PITA to get adjusted perfectly. And, if it's not adjusted perfectly, the sway control does not work well at all.
Guess I'm just interested also in anyone's experience with the Reese SC.
SteveH is online now   Reply With Quote
Old 09-15-2009, 07:01 PM   #4
Thanks Ron for the story. Since I'm in Mississippi it is a little far to visit you guy's shop, but sounds like they are really on the ball. I have a 2001 Tundra which has plenty of power but I am concerned about stability due to the rather narrow track compared to full size trucks. I'll look into the Easy-lift. I thought the new Reese would maybe have some advantages because of the friction material. I had planned on a Dual cam, but several friends have the Equalizer and like the fact that they are no chains to deal with. Maybe someone will have some towing experience with the SC.
Old 09-16-2009, 04:08 PM   #5
Montreal , Quebec
Just to clarify, I did tow with the SC and wasn't happy with it. Ride was too stiff; also meaning I was beating up the trailer. I've attached a picture before I changed my hitch. Notice, the front sitting higher than the rear.
Old 09-16-2009, 04:42 PM   #6
SteveH's Avatar
San Antonio , Texas
So, simply stated, you've gone from a trunion type hitch that was probably not setup correctly, to a round bar type hitch that is setup correctly.
It is a well known fact that the trunion bar hitches, size for size, ride rougher than the round bar hitches, and to counteract that issue, lots of people have gone to one step lighter trunion bars.
It is also clear in your picture above the hitch is not setup properly, so it comes down again, to setup.
A good hitch setup improperly will not work well, no matter the manufacturer. Do you happen to know the tongue weight of your trailer and the weight rating of the Reese trunion bars you were using?
Old 09-17-2009, 06:29 AM   #7
Montreal , Quebec
The tongue weight is about 650 lbs. My Trunnion bars were rated at 750 lbs. One big thing as well to note; that with my new welded shank/ball-mount setup my hitch-ball is 5" closer to the rear bumper; which makes a huge difference in the overall feel.
Reese copy of Equalizer 63air Hitches 27 06-14-2009 03:21 PM
Equalizer vs Reese Dual Cam SteveH Hitches 18 06-11-2009 11:01 AM
Equalizer vs. Reese Dual Cam for 23' Int'l CCD? mmccurdy Hitches 9 11-10-2007 12:10 PM
Reese & Equalizer: Functional difference? Gen Disarray Hitches 16 07-18-2007 10:33 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches 3 08-31-2006 12:48 PM
