Old 04-16-2011, 12:44 PM   #1
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Unhappy Reese Part Number 26002->26102
Reese did an interesting thing in the last year.
They discontinued the 26002 longer arm cadmium plated Dual cam arm assembly and replaced it with the shorter zinc plated 26102.
I was replacing my two accident failed hanger bracket, bent arm assembly while I was picking my trailer last week at AS of Spokane.
The new 26102 cannot be adjusted to have the cam in the proper position for sway control since the assembly is shorter.
The new assembly has to be mounted approx 1.5 inches further aft.
We mounted the 26102 in the old holes and adjusted it as far aft as it would go.
Tension on the WD bars and assembly was adjusted to balnace the truck and trailer.
On my way home both of the outer bolt heads on the left bracket sheared "popped" off. Fortunately there was enough bolt left to keep the bracket in place.
The next morning I wnet out to find one of the right bracket bolt heads sheared off. I found it a few feet away.
I called Reese and they said "we have had a bath of bad bolts". Huh?
At this point I am ready to switch to a different system.
See my thread http://www.airforums.com/forums/f437...day-75617.html
Michelle TAC MT-0
Sarah, Snowball
Old 04-16-2011, 01:07 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Michelle
Please post some picture if you can.
2004 Excursion 4x4
Old 04-16-2011, 07:02 PM   #3
Photos of old and new.
First two pictures are of the old/removed parts. The second are the new parts mounted and the sheared bolts. I would have a picture of the bolt head but it is in my truck which is in for routine service.
ID:	127141   Click image for larger version
ID:	127143   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
Old 04-16-2011, 08:20 PM   #4
1985 31' Excella
Fresno , Texas
Just curious are they tek screws or bolts and nuts. I have seen tek screw heads break off when they were installed with a impact type drill.
I found a good buy last week,a Reese class V Titan hitch almost new with no signs of wear for $50.00. My class IV was a little light for my utility trailer. Now I can switch things out if I plan to load the trailer to capacity.
Wsmith is offline   Reply With Quote
Old 04-16-2011, 09:17 PM   #5
HowieE's Avatar
Images: 12
From the looks of the last picture I have also got to question the torque that the self taping screws were put on with. If the screws had seared off do to load from the bars they would have sheared off clean with the frame. The heads popping off while leaving enough material to support the bracket makes me think the screws were over torqued. There is no reason to apply heavy torque to a screw or bolt that is loaded in a shear moment only.
This reminds me of the over torqued wheel nuts that are set in the heat of summer and they brake the stud on the coldest day in the winter
2004 Excursion 4x4
Old 04-17-2011, 05:29 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Heads popping off heat treated and then plated bolts are not that uncommon. It is caused by what is called "Hydrogen embrittlement". I was the materials engineer for Outboard Marine Corporation and responsible for failure analysis and production processes. Bolts that have been heat treated and then plated (either cad, zinc or other plating) need to be baked to drive the hydrogen out of the metal. Failure to do this step may result in the bolts failing at very reduced stress. The hydrogen is generated during the plating process. Some high strength, grade 5 and 8 bolts , even if they are not plated, are subject to having the heads popping off due to improper radius at the transition to the head.
Old 04-17-2011, 09:01 AM   #7
I am not sier what you mean by TEK screw heads.
The bolts are washer head. Cast or stamped then zinc plated. The bolts were not highly torqued. If they had they would have pulled out of the "milder" steel of the frame.
Remember: Reese admitted to a "batch" of weak bolts. The problem has since been "corrected".
Michelle TAC MT-0
Sarah, Snowball
Old 04-17-2011, 09:43 AM   #8
1977 31' Sovereign
1989 34' Excella
TEK bolts are produced by cold upset forging followed by machining. This gives them a favorable grain structure. If the dies are too sharp, they do tend to produce a stress concentration at the transition radius between the body and the washer head. This is the cold worked area that the hydrogen attacks, if the baking step is inadvertently left out of the process after the plating.
Old 04-18-2011, 07:49 AM   #9
FLMarine's Avatar
2009 27' FB International
_ , Florida
I had a similar reese setup and the thing happen to me. I have a 2009 27fb with a 2005 Dodge 2500 4x4 diesel. The first time it happened about three hours after I bought the trailer. Lucky for me I was visiting my buddy who also has an airstream and he had a threading kit and some extra bolts and we replaced the sheared bolt so I could tow it home. On the way home the second original bolt sheared off.
I will add a picture tonight that shows where the second bolt sheared off. The dealer I bought the airstream from was great and paid to have it repaired by a Reese dealer near my house since I live 4 hours from the original dealer which is Out-of-Doors mart in NC. Again nothing but good things to say about how they helped remedy the problem.
I had all the bolts replaced with grade 8 bolts and so far it seems to have worked. I also found the bolt head on the ground at the gas station when I was refueling.
I'll let everyone know if I have any mote issues. I'm also going to switch the 1200 lb trunnion bars for the 600 or 800 bars in the next week.
FLMarine is offline   Reply With Quote
Old 04-18-2011, 08:43 AM   #10
I am replacing with grade 8 bolts as well. Tapped and if possible nuts on the inside.
Michelle TAC MT-0
Sarah, Snowball
Old 04-18-2011, 10:51 AM   #11
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
I'm considering welding the brackets to the frame, as I found the bolts can work their way loose and can strip a thread if too much torque is applied.
Rig: '97 30' Limited
Towed by: '13 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 04-18-2011, 12:10 PM   #12
HowieE's Avatar
Images: 12
I am going to ask each of you that have had this problem to check one more thing. Since there is virtually no load other than shear, and that is minimal, on those bolts I would ask you to check this. The only load normally would be the force to overcome the friction of the bar riding up on the cam and that would not be applied along the axis of the bolt.
The Reese Straight line hitch has a design flaw in that on a tight backing turn the outside bar can contact the yoke. This contact normally results in bending the L bolt but if the bolts are out of spec it could cause the forward bolt head to pop off.
The picture shows the contact. The shallower the angle on the yoke to the frame the greater the likelihood of contact. I had to grind about a 1/4 in. of material at the point of contact to relieve this problem.
Those effected please look at the yokes and bars at this point of contact to see if there is evidence that they came together.
2004 Excursion 4x4
Old 04-18-2011, 01:32 PM   #13
dznf0g's Avatar
Oswego , Illinois
Doesn't seem to be an issue with the new part number. I read all the postings re. your contact issues and I can't see how it can happen with the new shorter parts....IF your use 5 links under stress. I have PLENTY of clearance. HOWEVER, I got, apparently, the old instructions used with the longer cam assemblies. I now have to run the adjustment all the way out to get a proper fit to the spring saddles. Flip em and I have to run them all the way in. The distance from the ball socket center to the cam arm bolt needs to be about 3/4 - 1 inch farther than the instructions I got say to do!
Old 04-18-2011, 01:43 PM   #14
HowieE's Avatar
Images: 12
How about a picture of the new Shorter part? Not sure what part you are mentioning that is shorter. What Reese could have done to eliminate the contact was to turn the yoke 90 degrees and have the thinner demention facing the bar.
2004 Excursion 4x4
Equalizer vs. Reese dual cam road test dznf0g Hitches, Couplers & Balls 25 08-02-2011 06:30 PM
What's this part for on Reese W-D hitch? amm3824 Hitches, Couplers & Balls 13 03-17-2011 09:45 PM
Reese snap up brackets Kman Hitches, Couplers & Balls 0 02-05-2011 01:03 PM
What is this part? (front end shelf) SpaceEgg General Interior Topics 2 01-09-2011 05:11 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
