Old 05-13-2008, 09:04 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Reese on Ebay
There is a set of Reese heavy duty sway controls on eBay. They must be used with the bars that have the pre-formed ends (not the straight ones with bolt on cups)
eBay Motors: reese Dual Cam High Performance Sway Control (item 290229331279 end time May-16-08 08:37:44 PDT)
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-13-2008, 09:37 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
THere are important parts missing. I would be wondering where is the rest of the trailer side stuff.
Michelle TAC MT-0
Sarah, Snowball
Old 05-14-2008, 06:26 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Outside of the bars, these are the next highest cost part of the dual cam solution.
You can in fact get replacement parts for the dual cam system from Reese or one of the resellers out there. If you could get this for around $25 or less (stress the less part), I think one could put together a dual cam system for less than could be bought new. Keep in mind, before metal prices went through the roof, I paid between $150 and $175 delivered for the dual cam system, new. Here is a Internet vendor that sells the whole kit for about $200 shipped (minus the bars):
All Reese Sway Controls | Drawtite | Reese | Hidden Hitch | Blue Ox | Rola
eBay also has the bars from time to time as well, but be warned that you really need to do your homework before buying the bar sets. I started off with 1200lb bars with my Chevy sedan, then when I went to the Suburban (3/4) ton, there was nearly zero deflection on the 1200lb bars. Eventually, I went down to the 600lb bars and the dual cam became more responsive with the firmer suspension 3/4 ton Burb. I got 2 sets of bars off eBay...800lb and 600lb both for less than $40 shipped, each. The price on the bar sets new starts at about $150:
Draw-Tite Trunnion Spring Bars (600 lbs.) 6662
There are a number of Internet based sales, I just used this one as a reference.
Old 05-14-2008, 09:24 AM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
This is the sway control part of the Reese system only. The rst of teh stuff would come as a WD hitch assembly. This takes teh bars with pre-formed ends, as was previously mentioned.
You can buy these as a pair, just as listed, with out the trailer side stuff.
I run this system with a Reese round bar WD hitch. I had problems with it from brand new, one of the HD cam arms was bent from the factory.
Uwe
www.area63productions.com
The new Reese add rfield54 Off Topic Forum 9 04-09-2005 11:50 AM
See your Airstream in the next Reese ad! Airstream Life Commercial Listings 10 11-24-2004 02:54 PM
What kind of Reese is it? Towster Hitches, Couplers & Balls 25 01-11-2004 10:52 AM
Reese hitch dlorahcof Hitches, Couplers & Balls 3 09-13-2003 04:11 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
