Old 12-22-2005, 08:11 AM   #15
1996 30' Excella
Brighton , Michigan
Reese sells a hitch ball lube "OnThe Ball Lube" which you can find at Camping World. It is about a 140 weight lube and should be used on the ball and daily on the trunions where the mount to the hitch head. In fact if you look at the head there are lube holes over the top trunion. My old instruction sheets say to lube daily even if you don"t unhook. The current hitch head is 20 years old and I would guess has 100,000 tow miles. I clean the head where the trunions run and the ball every time I hook up and use the "On The Ball Lube" every day at the trunion locations and the ball when I hook up. Don't forget to clean out the hitch cuppler on the trailer on a regular basis also.
apple 1 is offline   Reply With Quote
Old 12-22-2005, 10:43 AM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My hitch says "oil" where these holes are located. I have been useing the Reese lube you refered to, I think. Is it the white stuff?
Richard
Old 12-22-2005, 12:51 PM   #17
1996 30' Excella
Brighton , Michigan
The stuff I have is black, however a bottle of On THe Ball Lube lasts about 10 to 15 years and the last time I putrchased it was 7 or 8 years ago, so it may now be white.
Old 12-22-2005, 01:53 PM   #18
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
The suggestions you've gotten so far generally appear to be good ones, but you may also wish to have a qualified person check your hitch installation also. From the amount of wear you've described, it sounds to me as though your hitch may also be incorrectly installed - a number of dealers are negligent in that regard. Two different Airstream dealers did a terrible job installing my Reese High Performance Dual Cam Hitch last year, and I finally took my trailer to a non-Airstream dealer who correctly adjusted the hitch.
Reese has good technical assistance via telephone, and thier website @ reeseprod.com also has quite a bit of information.
Here's some pertinent quotes from their website:
What kind of maintenance do I need to do to the weight distributing hitch
WDH and sway controls?
Lubricate the ballmount sockets and spring bar trunnions to prevent rapid wear. When hooking-up, place one drop of oil on the top and a second drop on forward side of upper trunnion. Place a third drop on the rear side of lower trunnion before inserting trunnion into ballmount. Use a heavy oil such as "REESE ON THE BALL". Don't forget to lubricate the hitch ball with one or two drops also. Trunnion should be lubricated each towing day. It is not necessary to unhook the spring bars however, as there are two oil holes in the ballmount top plate for upper trunnion lubrication. Lubricate lower trunnions with one drop at contact point between trunnion and lower socket. Excess oil, dirt, and grit should be wiped out whenever trailer is uncoupled.
Can I grease the Dual Cam Sway Control (DCSC)?
Do not grease the cam and cam arms. The Dual Cam was designed to use metal-to-metal friction. Heavy greasing of the cam and cam arm surfaces with affect performance. If noise is offensive, a very light coating of lubricant, such as Vaseline, may be used. Tongue weights over 1,200 lbs. may require a light coating of grease to reduce friction and prevent excessive wear. The Dual Cam Sway Control DCSC is not to be lubricated on the cam arms when the tongue weight is under 1,200 lbs. Instead you will want to apply a thin coat of a petroleum jelly, such as Vaseline. This will act as a poor lubricant, but works well to dampen the sound. For trailers with over 1,200 lbs. tongue weight you should apply a couple of drops of an 80/90 gear lube to the cam arm to prevent excessive wear caused by the increased tongue weight.
John
Flyfisher
flyfisher is offline   Reply With Quote
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese hitch on semi-steep slopes? 3Ms75Argosy Link Archive 1 09-15-2002 12:08 PM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
