Old 06-07-2010, 06:59 AM   #1
1986 25' Sovereign
Plant City , Florida
Question Reese head/receiver cracked
I am currently inspecting everything on the stream for my upcomming trip to GA. I noticed that the head of my dual cam reciever is cracked on both sides where the c channel is welded to the ball mount.
Does any one know if this is under warranty from reese and if so who could I contact.
TIA
ck21084 is offline   Reply With Quote
Old 06-07-2010, 07:10 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Reese had a problem with this a few years ago. Some who had it thought it was caused by the fit on the drawbar being a little loose and the stress caused by drawing down the bolts was the cause. A couple friends made thin shims to take up the "slack " and seemed to have some success but I don't know what the final resolution of the problem was or whether Reese owned up to it.
Certainly worth a phone call to find out.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-07-2010, 07:10 AM   #3
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I think age has something to do with the wear or warranty. Why not take a picture and contact Reese online or go to a local dealer.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-07-2010, 08:05 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Call Reese 800 521 0510 and ask. They have been quite good at replacing items that fail because of the image they want to protect.
Be very careful inspecting anything you get from them now days. Product is made in Mexico and has no quality control as noted in the second picture. 2 sets of these hangers came in unusable. I rewelded the holes closed and drilled my old hangers.
ID:	104324   Click image for larger version
2004 Excursion 4x4
Old 06-07-2010, 08:27 AM   #5
1986 25' Sovereign
Thanks for the info. I called Reese and they ask for pictures. Now I have a new ball mount on the way.
Chris
crack, dual cam, reese, warranty
cracked wheelwells Chas Wheel Wells 20 10-02-2007 09:22 AM
cracked Door frame Didgiman Doors & Locks 10 06-21-2007 12:00 PM
Cracked Plugs... canny_banjo_man Mechanics Corner - Engines, Transmission & More... 16 04-23-2006 01:10 AM
Reese Receiver needed jasper2222 Hitches, Couplers & Balls 2 10-06-2004 07:54 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
