Old 06-24-2004, 12:17 PM   #29
FireFighter's Avatar
bay city , Michigan
Pull Rite
way to go Mark Pull Rite is a bad azz hitch if i did not have two tow vehicles i would have seriously considered this.
FireFighter is offline   Reply With Quote
Old 06-24-2004, 12:17 PM   #30
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I installed my DualCam HP by myself. I measured about 30x and drilled once. Took about an hour tops. Not difficult at all. Not sure what some folks think this whole thing takes to setup, but I would say that it is not that much more difficult than installing a friction setup.
Old 06-24-2004, 12:19 PM   #31
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by dscluchfc
Jack,
Still, once installed, you have to find a level straight road of several hundred feet to line the tow rig and trailer up STRAIGHT, then set the cams and saddles in the proper towing position.
my manual says "100 feet". most parking lots should be more than adequate.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-24-2004, 12:21 PM   #32
bay city , Michigan
100 feet
Silvertwinkie did you do the straight driving to finish the setup, sounds like you just measured and that is all enlitin us please
Old 06-24-2004, 12:24 PM   #33
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
You can do it in a hundred feet...300-400 ft is better because you can set it, and then drive a hundred feet and check it...and repeat to make sure you hit it perfect.
dscluchfc is offline   Reply With Quote
Old 06-24-2004, 12:38 PM   #34
Aluminut
2004 25' Safari
. , Illinois
I had measured and installed the brackets, then I drove the coach around town (much more than 100'). I then adjusted the "adjuster bolts" on the cam, took it back out around the block and it was perfect.
Old 06-24-2004, 12:43 PM   #35
Aluminut
2004 25' Safari
. , Illinois
BTW...moving the coach made no difference at all. FWIW.
I could have just measured and installed without moving the coach.
Of course your results may vary, always wear your seatbelt, never speed or use a metal ladder in a storm (as a standard disclaimer).
Is dual cam better than friction sway control? Fogducker Hitches, Couplers & Balls 6 02-12-2004 09:37 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
friction vs. dual cam sway Craig Hitches, Couplers & Balls 8 04-29-2003 11:30 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
