Reese, For The Good Of The Order
This may be a problem for you and I offer this as an item to check.
While adjusting my Reese Dual Cam with the newer trailing arms I noticed a problem. When making a sharp turn while backing up the outside bar can touch the Dual Cam High Performance Sway Control.I have heard of several that have had the sway control arm brake and this may be the reason. The attached picture shows the point of contact and how I ground some relief.
This is more than likely a problem of the heaver bars because of their thickness but the problem could exist on lighter bars depending on other adjustment factors
My test was on level ground. If the trailer was up hill to the TV the problem would be greater so look for any marking on the sway control or the arm that may document a past contact.
2004 Excursion 4x4
