Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 11-07-2009, 08:41 AM   #1
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Reese Dual Cam Sway Control with SOB WD hitches?
Can a Reese Dual Cam Sway Control be used in combination with other brand weight distributing hitches. Specifically, can it be used with a Husky?
Pay no attention to the man behind the curtain- WoZ
Old 11-07-2009, 11:02 AM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings Lumatic!
I am virtually certain that the Husky won't work with the Dual Cam HP, but I would be more confident that the classic Dual Cam that uses U-bolts for mounting might work -- particularly with the trunion style Husky. The key would be whether the bolt-on saddle would match the bolt-holes used to attach the chains on your Husky bars -- I imagine that it would be possible to bore new holes to match the saddle, but don't know whether that might not, in some way, compromised the integrity of the bars.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 11-07-2009, 01:07 PM   #3
Lumatic's Avatar
How is the "Dual Cam HP" different from the "classic Dual Cam"? just the U bolts?
Old 11-07-2009, 02:49 PM   #4
Profile:  1977 31' Sovereign
McHenry , Illinois
Cams are bolted onto the w/d bars rather than using a bend in the w/d bars that act as the cams. The bolt on cam follower levers are also entirely different.
Old 11-08-2009, 09:37 AM   #5
Anna , Illinois
Images: 156
I thought that a couple of photos might help to illustrate the difference:
Classic Reese Dual Cam Sway Control as Installed on my '78 Minuet
Reese HP Dual Cam Sway Control
Kevin
Kevin D. Allen
AIR #827
Old 11-08-2009, 10:23 AM   #6
Lumatic's Avatar
Thanks does Reese still sell both versions?
Old 11-08-2009, 12:27 PM   #7
Anna , Illinois
Images: 156
Greetings Lumatic!
Yes, Reese does still offer both versions, but the classic style is something of a back-burner item that isn't even mentioned on their website. As an example, I found the classic style Dual Cam listed at this link.
Kevin
Kevin D. Allen
AIR #827
Old 11-12-2009, 07:09 AM   #8
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
My father had a Reese Dual Cam (classic) installed and operating with his Eazilift round bar hitch. He said it "helped", but at the time he also had TWO friction sway bars on the trailer. It was the big three axle Avion, and he towed it with a 3/4 ton Suburban.
Old 11-12-2009, 09:38 AM   #9
Commercial Vendor
Profile:  Corona , California
Years ago, many owners used 2 friction type sway controls.
Most of them still had sway.
The trick is not what you may use, but is it the correct type and rating for the intended job, as well as properly installed, and, properly adjusted.
Unless the answer to the above is yes, yes, yes, problems will still prevail.
Load equalizing hitches is not a rocket science, but unfortunately, many owners, to this day, refuse to accept facts, and totally disregard professional experiences.
Any travel trailer will track correctly, without a sway problem, "IF" and only if, the three factors are indeed positive, along with a good tow vehicle.
If even one is negative, the "booze" is certainly on the menu, at every truck stop. The booze helps reduce the "white" knuckles, or seemingly so.
Andy Rogozinski
Inland RV Center
Corona, CA
Reese Dual Cam Sway Control for round/trunnion hitches rogerdodger Hitches 18 08-04-2009 09:46 AM
TT sway w/ Equal-I-Zer or Reese Dual Cam hiker Hitches 79 09-14-2007 12:34 AM
WANTED;Reese Dual-Cam Sway kit,#R26000 Fogducker Parts Archive 0 02-13-2004 06:50 PM
Reese dual cam sway - fit??? Craig Hitches 4 06-18-2003 05:50 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches 19 03-19-2003 07:17 AM
