Old 08-01-2009, 01:29 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Reese Dual Cam Sway Control for round/trunnion hitches
I would like to use the reese dual cam 26000 for my round bar Eaz-Lift. Anyone else using this dual cam on their round bar or trunnion systems? I would like to hear about them, good or bad.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 08-01-2009, 02:01 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the ends of the bars are set to accept the cams there should not be a problem. If they are just straight it would be a waste of effort since it is the pressure to lift the bars off the cams that is what reduces sway.
Now that said there is an inherent problem with the newer Straight Line Sway Control Arms. They tend to strike the bars while in a tight turn, most common while back up. Note the material I had to grind off the yoke to prevent this.
2004 Excursion 4x4
Old 08-01-2009, 02:03 PM   #3
HowieE's Avatar
Images: 12
Hope the picture shows up this time
2004 Excursion 4x4
Old 08-01-2009, 02:45 PM   #4
My Eaz-Lift is a round bar, so cannot tell if there will be interference with the link until it is installed. Thanks for the heads up.
Roger
Air# 29488
Old 08-01-2009, 03:05 PM   #5
HowieE's Avatar
Images: 12
If it is a round bar and do not have the cam saddle at the end there is no reason to install them as they will not act as a sway control.
2004 Excursion 4x4
Old 08-01-2009, 06:34 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Roger!
If your round bars have the chains mounted with two throught bolts, there is a high probability that the "classic" bolt-on saddles will work. These bolt-on saddles are available as separate components from Reese unless you purchase the "classic" Dual Cam unit that mounts with large "U"-bolts. I have seen this "classic" style Dual Cam utilized with a "round-bar" hitch, but haven't encountered anyone utilizing "round-bars" with the "High-Performance" Dual Cam.
The bolt-on saddles are the two smaller black steel componentes in the photo above.
Kevin
Kevin D. Allen
AIR #827
Old 08-02-2009, 08:22 AM   #7
Thank you for the info. I found a wbsite that sells the classic. It states:
"4-1/2" from the end of the spring bars must not exceed 1-1/2" in width or 5/8" in thickness for cam adapter to work". My spring bars are 1 3/4" at the 4-1/2 from the end, I wouild have to grind a little off the spring bar for it to fit. Should I do that, or Better to buy new spring bars with the curved ends. Thanks for the help.
Roger
Air# 29488
Old 08-02-2009, 01:46 PM   #8
HowieE's Avatar
Images: 12
"4-1/2" from the end of the spring bars must not exceed 1-1/2" in width or 5/8" in thickness for cam adapter to work". My spring bars are 1 3/4" at the 4-1/2 from the end, I would have to grind a little off the spring bar for it to fit. Should I do that, or Better to buy new spring bars with the curved ends. Thanks for the help.
Please post the site your are referring to.
You can not grind down the bars because you will drastically change the bending factor and thus the deflection within the bars, concentration the force at the point of the grinding.
As you may gather from my other posts I generally am willing to reinvent or change any thing engineered but not this one. You should consider buying a system designed for the job.
2004 Excursion 4x4
Old 08-02-2009, 02:36 PM   #9
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Roger!
In examining my spring bars, the main reason for the the thicknes limitation is the size of the "U-bolt" that attaches the rear-most portion of the cam or "saddle". It would appear that switching to a longer u-bolt should allow for use of your bars without further modification.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 08-02-2009, 02:41 PM   #10
Here is the site:Dual Cam Sway Control 4" or 5" Frame 26000 : Trailer hitch bike rack and trailer hitches - etrailer.com
They give the max dimension for the end of the bar. My bar exceeds it. As you stated, best not to mess with the bars if too wide. too bad they didn't make the cams a little wider to work with a variety of bars.
Roger
Air# 29488
Old 08-02-2009, 02:51 PM   #11
Kevin, it looks like the cam width, and u-bolt width max is 1-1/2 inches, not the length. If I can figure out how to attach the cam with larger u-bolts without them coming loose while traveling, ie larger than the cams, I would give it a try. It would have been better if the cams were wider so the supplied u-bolts would go around my bars.
Roger
Air# 29488
Old 08-02-2009, 03:08 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The arms on my Reese would work with the setup posted earlier. My only concern would be the placement of the bracket for the cam arms. I am concerned that the propane bottles might be in the way.
Richard
Old 08-02-2009, 03:22 PM   #13
Richard, good point. Here is the website that has the install instructions in pdf format. Draw-Tite Dual Cam Sway Control Fits 4 inch and 5 inch Trailer Frames 26000#
Roger
Air# 29488
Old 08-03-2009, 03:26 PM   #14
SteveH's Avatar
Common Sense , Texas
Roger,
My father did just what you want to do...added the Reese anti-sway cams to an Eazy lift hitch, and he had to grind down the bars a little off each side at the ends only. He had the old style cams, the only ones available at the time, and it worked fine.
TT sway w/ Equal-I-Zer or Reese Dual Cam hiker Hitches, Couplers & Balls 79 09-13-2007 11:34 PM
Reese Dual Cam Trunnion Bars dscluchfc Hitches, Couplers & Balls 17 04-21-2005 05:52 AM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
