Old 10-09-2006, 10:49 PM   #1
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Reese dual cam strangness. help please
Let me tell you whats hapening.
25 foot Safari FB. When I make sharp turns there are clanks. I was looking at the hitch set up and noticed...
The brackets that clamp to the trailer frame have moved forward about 4 inches. Is there a bigger problem for me other than loosening the clamps resetting them to the original spot and tightening them back up?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 10-10-2006, 04:02 AM   #2
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Clamps
Of course, they are not supposed to move when properly tightened. Moving them back to their original position and refastening them should solve your problem. Be careful not to overtighten the U-bolts....you can bend/distort the frame. It's best to use a torque wrench and torque the nuts to spec. Bill
lebolewis is offline   Reply With Quote
Old 10-10-2006, 05:10 AM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Bill called it correctly. Reposition the brackets, and torque them to spec. If you continue to have squeaks and grinds, lube the ball lightly, and lube the tabs on the trunnion bars (with Reese hitch lube or a little wheel bearing grease) where they fit into the ball mount. If the dual cams squeak, use a little vaseline on the surfaces to quiet them. The cams work on friction, so don't use grease on them!
Roger
Old 10-10-2006, 05:26 AM   #4
1984 31' Excella
Norfolk , Virginia
Images: 11
Dual Cam
Going camping
Here, I hope are the instructions emailed to me from Reese. One for the drawbar/ball mount adjustment and one for the dual cam setup and adjustment. Here Goes.
Beginner
Beginner is offline   Reply With Quote
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
