Old 04-25-2009, 04:40 AM   #169
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Ok, I think I follow you.
"The next shank notch down is 1 1/4" lower then the coupler and really creates a V effect with the trailer nose way down. The lower shank notch also causes my rear suspension to drop 2". "
Is it 2" lower with the WD bars snugged up?
Did you measure your wheel heights before and after each adjustment.
What were your wheel heights before/after in the picture.
Also what were they with that 2" drop
Also; to get to 5 links with less pressure tilt the ball forward a bit.
Another thing I see in pic is that shank is really long if you cut it to get the ball closer to your bumper that will do two things.
Less tailgate drop
Less sway
I cut about 5" off mine, made a noticable difference.
If you want to setup up a time to call tonite or tomorrow we can get this fixed.
'77 Sovereign Intl 31' CB
Old 04-25-2009, 07:38 AM   #170
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Less tailgate drop
Less sway
Yes, I get 2" rear suspension drop with the WD bars set and slightly bent. I also measured the wheel well gap, and checked the levels at each attempt. The rear tires are 35 1/2" and drop to approx. 33 1/2" no matter what tilt I try with the lower shank setting. Although some tilt settings changed this by as much as 1/8" I still have about a 2" drop no matter what I do at the lower shank setting. The front tires actually gain 1/4" on top of this at the lower shank setting. The directions said to measure the top of the receiver hitch and the bottom of the coupler when both the tow vehicle and the trailer were level and to try to compensate for the difference using the shank settings. In the video they show the example of a 4" adjustment on the shank to compensate for a 4" difference. The closest I could come to this was at the current setting in which the hitch ball is 1/4" lower then the bottom of the coupler. I get off of work early Sun. and will try to take some pictures at the lower shank setting if that would help, but I don't I don't see how I could drop to the next shank setting down. I think I'll also try to adjust the tilt and work with the 5 link setting on the WD bars while using the current shank setting and take a pic of that. Perhaps I'm not correct in trying to use the shank setting that's closest to level with the coupler. I also don't understand why everyone seems to want to use only 5 links showing on the WD bars. It would seem that it could be different for different trailer/tow vehicle setups. One thing I didn't do was to set the shank in closer as you suggest. That may be the biggest issue. There are multiple holes in the shank to allow for this, and I should have thought of that. I'm going to work on this Sun. afternoon so any further suggestions are greatly appreciated. I'll PM you with my phone #. I really appreciate the advise.
Charlie
Pacerized is offline   Reply With Quote
Old 04-25-2009, 08:30 PM   #171
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Just a quick update as I've hooked up the Airstream to have it ready to take to a level lot as soon as I get home from work Sun.
The setting on the picture has the tilt at #6 which is the max. tilt. From this I can get to 5 links but it causes the trailer to tilt backward and makes it unleveled. I did put the shank in to the 2cd. hole but it still sticks out quite a bit. I suppose that I could drill another hole in it to push it back further into the receiver but I'm concerned if it's safe to do this. Cutting it off would not be necessary since it slides back a lot further without doing this. I wonder why the shank comes out so far at it's deepest setting in the receiver, I would hope that they shank would be designed correctly. I am going to try to lower the ball again Sun. and try setting the WD at 5 links and will take some pics at this setting. This will put the hitch ball at 1.25" lower then the bottom of the coupler. If anyone has any further advise it would be greatly appreciated.
Li Pets, I sent you a PM.
Thanks: Charlie
Old 04-25-2009, 09:13 PM   #172
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
You say tilt? which way tilt back?
I think they make them like that so you can back up in tight spots, not sure but it is better short, I never had issue backing up.
I learned this a long time ago, it acts a lever the longer it is. CanAm in Canada does most if not all his custom hitches with minimun length.
I've seen two in our LI group, like a Astro Van pulling a 34' etc.
Read this fore more
I also attended an advanced trailer seminar, same thing, shorter it is less sway they did it with models. Very clear cut.
There is a ratio of the axle front/rear length to the rear axle tow ball, do the math when you change it just a few inches the percent changes a lot.
In your case the longer it is the lower your bumper will drop as it levers it down.
So yes I would drill it.
Thanks: Charlie
Bottom line is you want to get the trailer as level as possible, try the tilt in the center position, with 5 links.
Is that level if you stand back and look.
Try the shank height at different spots until its level.
Once this is accomplished we can fine tune with ball tilt based on wheel well numbers. Then driving.
Give me the unloaded wheel well hights before and after.
My rig can do 75mph with one finger on the wheel and semi's passing.
Ps: I also have dual cams
Old 04-26-2009, 08:44 PM   #173
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
I worked again with setting the hitch down one more hole which is also the lowest possible setting for the shank. The 2 pics below are at this lower shank setting, max tilt forward #6, and using 5 links. When I did this I was able to show only a 1/2 inch drop in the rear suspension and a 1/4 inch drop in the front. The trailer is also showing between the lines on the level. What do you think of how this looks? I measured how far my old weld hitch ball came out of the shank and it was dead on with how far the new shank would be if I pushed it all the way forward and drilled a new hole for this. I attempted to do so and was able to drill through it with my titanium bits but they only went up to 3/8", when I tried to use a brand new 1/2" oxide bit it wouldn't faze it. I'll have to stop by home depo and pick up 2 larger titanium bits tomorrow. I can see what you mean by the leverage effect the longer shank has on my bumper.
Thanks again for the help.
Charlie
Name:	hitch03 bottom shank max tilt 5 links.jpg
ID:	79314   Click image for larger version
Name:	hitch04 bottom shank max tilt 5 links.jpg
Old 04-26-2009, 09:03 PM   #174
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Thumbs up
That looks better, a 1/2" drop instead of 2"
How did drive?
Just get the hole drilled, you may need to take it a machine shop.
Old 04-26-2009, 09:12 PM   #175
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
I didn't have time to take it on a long drive, just to our local Target to check things out and work with it on a level lot. In the short 2 mile drive it seemed to handle a little better. I think it will be noticeable when I take off for Arches this Thursday night. I did think about taking it to a machine shop to have the hole drilled and waiting until I make it to Denver in a couple of weeks. A drill press would do a much better job.
Charlie
Old 04-27-2009, 07:36 AM   #176
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Charlie
Hi Charlie, I've been looking into a weight distribution hitch and have a question for you. In the second photo (post #173) your tongue looks bent up. Is this normal with weight distribution? I have a spare tire that fits behind the tanks and this would cause problems. Maybe it's just the camera angle.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-27-2009, 07:56 AM   #177
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
I think the effect in that picture is more the way that my tank covers sets on a metal wiring conduit in the front. It's always leaned back a little. If you look at the first picture I posted without the tank cover #166 you can see the effect of the WD bars. The bars distribute the weight back toward the trailer by springing action using the tongue as the leverage point, so I guess there is a slight change in the angle of the tongue. Post of pic showing how much slack you have between the spare tire and the body of the Airstream. Perhaps someone more knowledgeable could give some input but I don't think the bars would cause an issue for you.
Charlie
Old 05-01-2009, 07:56 AM   #178
Town , Michigan
Question for the dual-cam experts....
Do the recommendations made in regards to spring bar ratings apply to trailers other than Airstream? I came across this thread while researching how to properly tune my dual-cam sway control and have learned quite a bit thus far. I was hoping I could get some recommendations on my particular setup.
Tow vehicle is a GM 1500 Crew Cab, 7000 lbs GVWR and 13000 GCVWR. Trailer is roughly 700 lb tounge weight and 6000 total weight. I have 800 lb spring bars.
When hitched up, (as configured from the dealer, whom I don't believe configured my hitch properly) my rear end squats 3" while the front only 1/4" (as measured at the wheel wells) Does this sound right or should I have more even settling between front/rear?
barrickd is offline   Reply With Quote
Old 05-01-2009, 08:29 AM   #179
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by barrickd View Post
Q
Did you mean 3/4 of an in rear drop? 3ins. is almost beyond belief for that tongue weight. Confirm that please.
Yes the rules noted here apply to any WD hitch setup. The only difference is it is critical that an Airstream trailer ride parallel to the ground when done. This is because of the type of suspension used.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 05-01-2009, 08:37 AM   #180
Town , Michigan
Yes, my original post was correct. My rear end squats nearly 3" once hooked up and spring bars snapped into place. Again, my truck is only a 1500 (and no HD suspension) I was quite surprised as well when I took the measurements.
I have the high performance ballmount/shank with the grooved washer for ball tilt adjustment. The dealer set mine at near vertical, with 1 tooth showing on the ball mount.
Old 05-01-2009, 08:59 AM   #181
Wrong, wrong.
When a load equalizing hitch is installed correctly, and adjusted correctly, the Airstream should remain level, and the tow vehicle should drop, equally from thr front to the rear.
If, not, then adjustment is in order.
Also, you should be using 600 pound bars.
But, get the adjustment problem fixed first. Then as a test, when the rig is hooked up, ready to go, stand on the coupler and jump up and down. The coupler should move vertically a couple of inches. If not, then the bars are over rated and/or the truck suspension is to stiff.
Old 05-01-2009, 09:00 AM   #182
HowieE's Avatar
Images: 12
First thing is to through that head back at least 3 graduations and see what you get for measurement then.
Keep in mind as you tilt the head back you are putting more load on the bars and you will have to use the jack to lift the combination in order to snap the chains up. Also as the head goes back the ball goes down. In order to have the trailer ride level when done you may have to adjust the ball height and start over on the head tilt.
This is not a 5 min. job so pick a cool spot and have a few beers ready.
Try and get a 60/40 ration of rear drop to front drop. If you end up with a front axle drop of 3/4 of an in. this may start to change your tire ware pattern. If you are towing more than just driving the truck you may want to have the front end set up for the trailer load. Again be very careful who sets up the front end because there are no more shops that know how to do that than there are shops that know how to set up a WD hitch.
Let us know how you make out.
2004 Excursion 4x4
new reese dual cam Bing-Bing Hitches, Couplers & Balls 11 05-27-2007 12:40 PM
Reese Dual Cam HP Problem uwe Hitches, Couplers & Balls 14 05-24-2006 08:41 PM
Reese dual cam HP junbe Hitches, Couplers & Balls 12 04-07-2005 06:10 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
