Old 11-08-2010, 03:58 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Reese Dual Cam Position question,..
There are two holes that are on my hitch to lock the hitch bar into my truck hitch. Which one do i use? I have been using the lock hole on the farthest one from the ball because of the tight turn I have to make to get my Airstream in the driveway. I figured more clearance. The holes are about 2=3" apart. Does it really matter? Also, why are there two?
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 11-08-2010, 04:03 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Usually closer is better. Unless it interferes with opening a rear door on your TV, use the one closest to the ball. Others will chime in, I'm sure.
Old 11-08-2010, 04:17 PM   #3
dznf0g's Avatar
Oswego , Illinois
Some vehicle's receiver is tucked further under the bumper than others. My van is tucked so far under that I have barely enough room to use my Enkays. The PUs ans SUV I have towed with have plenty of room. It doesn't matter which you use, other than slightly increasing yo0ur effective overhang by using the furthest from the ball.
Old 11-09-2010, 06:40 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
the closer the ball is to the rear axle the better, there is a % of fulcrum that is beneficial.
'77 Sovereign Intl 31' CB
new reese dual cam Bing-Bing Hitches, Couplers & Balls 11 05-27-2007 12:40 PM
Reese dual cam strangness. help please Goin camping Hitches, Couplers & Balls 3 10-10-2006 05:26 AM
Reese dual cam HP junbe Hitches, Couplers & Balls 12 04-07-2005 06:10 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
