Old 05-24-2006, 08:41 PM   #15
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The heavy weight bars have a higher spring rate than the low rated bars. Therefore, the lighter weight bars are deflected more to give the same weight transfer. The cam dimensions are the same for both bars. That means the amount of spring force (when turning) will go up more when the heavier weight bars are used. Therefore, this would result in higher self centering forces. I do not understand why this would be a problem.
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
