Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-02-2004, 04:06 PM   #1
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
Reese Dual Cam & pipe
I'm was planning on installing the Reese Dual cam on my 2005 CC28' and when looking at a 2004 today I noticed the copper Propane line runs along the underneath of the a frame. The chain mounts that get screwed in are supposed to saddle up underneath the frame where the pipe is. Has anyone installed this on such a unit and did you have to relocate or move the LP pipe to do so? I did not have this problem on my '67. Thank you
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 07-02-2004, 04:18 PM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
. . . . another example of fine design engineering.
Old 07-02-2004, 04:21 PM   #3
Profile:
I just installed a Reese dual cam on my 31' International. Had to change out to flex hose from the regulator to the gas line under the trailer.
A bigger problem is now I cannot get my Airstream Aluminum tank cover over the gas tanks because the saddle brackets are in the way.
Navigator is offline   Reply With Quote
Old 07-02-2004, 05:26 PM   #4
Tin Hut's Avatar
Southlake , Texas
gas line
Nav, do you have any pics or advice on switching to flex line? Where did you connect back to your copper line under the trailer? I'm wondering what I'm getting into ....if its using a wrench to connect/disconnect or if you had to cut pipe. If you used the dual cam with the screw (bolt on) from the sides I'm surprised the saddle interferes. Sorry you have to deal with that, maybe I will too.
QUOTE=Navigator]I just installed a Reese dual cam on my 31' International. Had to change out to flex hose from the regulator to the gas line under the trailer.
A bigger problem is now I cannot get my Airstream Aluminum tank cover over the gas tanks because the saddle brackets are in the way.[/QUOTE]
Warning: (20%)
Old 07-02-2004, 05:31 PM   #5
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
I installed the HD Dual Cam on my Classic 25 without any problems. I simply removed one clamp from the propane line and installed the Reese parts. My only problem is that the chain brackets are back a bit too far because I have been too lazy to go get some shorter cklamp screws. There is no interference with the tank cover.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 07-02-2004, 07:45 PM   #6
Profile:
Tin Hut, Sorry, no digital yet. Had to cut the copper pipe based on the length of new rubber hose, which brought the new flared connection a few inches along under the bottom of the coach.
Dick
Old 07-02-2004, 08:14 PM   #7
Tin Hut's Avatar
Southlake , Texas
dual cam
John, did you have the chain brackets/saddles that are screwed into the frame or the ones that have the ubolts? Thanks.
Warning: (20%)
Old 07-02-2004, 09:35 PM   #8
Pahaska's Avatar
Images: 13
I have the HD Dual-Cam in which the arm mount is screwed to the frame, but I am still using my old Drawtite chain tip-up hooks that clamp to the frame. There are no U-bolts. There was no problem in installing either one. With one clamp removed, the propane line could be easily moved down out of the way.
John W. Irwin
Old 07-02-2004, 10:02 PM   #9
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
I installed the new Dual Cam HP on our 2004 Safari. No movement of the line was really needed. I did push it out of the way while installing, but as far as removing clips, relocating lines, etc....survey said....buzz....nope.
Engineering is fine and it works well.
Reese dual cam HP junbe Hitches 12 04-07-2005 06:10 PM
Reese Friction Control or Dual Cam? donreitz Hitches 34 06-24-2004 12:43 PM
Older Reese Dual Cam for Sale Barkingspider Parts Archive 3 12-24-2003 09:34 PM
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
