Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 04-10-2010, 06:16 PM   #1
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Reese/Draw-Tite Bar Weight
Hello All,
I am trying to figure out which bars to get for my Weight Distribution Hitch. Our trailer is 3500# GVWR with a Hitch Weight of 446# maxed out.
There is a single bar 600 TW and 4000 Trailer Weight or the double bar which is 600 TW and 10,000 Trailer Weight? I think the dealer I am working with wants me to use the single bar, but I am more inclined to use the double bar, but fear that it is overkill for our trailer weight?
Please advise. Thanks.
boutdoors is offline   Reply With Quote
Old 04-10-2010, 06:52 PM   #2
Originally Posted by boutdoors View Post
Hello All,
The answer, in part, depends on the exact tow vehicle you will be using.
A proper rated load equalizing hitch, matches the trailer to the tow vehicle, always.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-10-2010, 08:29 PM   #3
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Andy, Here's the breakdown:
TV - 2010 V6 Tacoma with tow rating of 6500#
TT - 2010 16' Sport, 3500# GVWR, 446# TW
My dealer said that I should get the lightest bar weights as possible and I assume he is referring to a single bar weight distribution system, but I think I should get the 600# trunnion weight distribution system.
Old 04-11-2010, 04:22 AM   #4
I agree with your thinking.
A Reese dual cam would do a good job.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-11-2010, 10:49 AM   #5
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Anyone else have any thoughts on which reese bar weight I should use?
Besides Reese, I was thinking of going with Equal-i-zer, but was cautioned yesterday that their might not be enough tongue weight with my unit to make even the 600# bars work effectively.
Old 04-11-2010, 11:15 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Boutdoors, are your trailer weight and tongue weight figures actual or something your reading on a chart? The two are not always the same. When your trailer is loaded for travel, take it to the truck scales and weigh the trailer and tongue weight separately for the real story.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 04-11-2010, 12:45 PM   #7
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
The numbers are off of the Airstream Web site.
The problem is that I have to tow from the dealer about 100 miles and want Weight Distribution put on before I tow it, so, no time to load and test on scales.
Old 04-11-2010, 04:32 PM   #8
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Your Fine....
Of course if you had a Ford F250 or Chevy 2500 you wouldn't have any issues...
Or - if you intsall a "ha-ha" or "pp" you could use a Suzuki Swift...
All said "tongue in cheek"....
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-12-2010, 09:09 AM   #9
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Thanks John, I know I am fine, but still have not gotten an answer to which spring bars I should go with.
600#/10,000#
or use the single bar system rated at 400#/4,000#
Thanks.
Old 04-12-2010, 11:07 AM   #10
Ag&Au's Avatar
Port Orchard , Washington
600#/10,000#
Thanks.
I would strongly recommend that you call the hitch manufacturer's customer service and ask for their advice.
On these forums, you will likely get varied answers, and obviously they can't all be right.
The dealers don't always have the best advice either. They are in the business of selling trailers, with hitches being secondary.
The engineers that designed the hitch, work for the manufacturer, and that is where the most reliable advice is going to come from.
Regards,
Ken
Old 04-12-2010, 11:27 AM   #11
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Thanks Ken,
The only problem is I cant find the Customer Service phone number for Reese or Draw-Tite. All they have on their web site is an e-mailable form??
Does anyone have the customer service number for Reese or Draw-tite?
Thanks.
Old 04-12-2010, 12:07 PM   #12
Ag&Au's Avatar
That is weird. I don't think I have ever seen a company go to more trouble to hide their phone numbers. I look all over the internet. Apparently this is the parent company and I can't even find their number: Cequent Website - A TriMas Company .
Regards,
Ken
Old 04-12-2010, 12:19 PM   #13
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Yah, if someone has it, we should start a thread of customer service numbers if there is not one already.
Old 04-12-2010, 12:24 PM   #14
_
600#/10,000# or use the single bar system rated at 400#/4,000#
the answer is found in a previous thread, in the last few links in post #11...
http://www.airforums.com/forums/f464...ill-61635.html
basically the same trailer as here...
http://www.airforums.com/forums/f464...-ii-21000.html
see posts #27 AND #50 in that thread.
the dual cam has the advantage of being able to UPrate the w/d bars without buying a new hitch head...
with the e'I'zer, most trunnion bar models are head/bar specific,
this is common for trunnion style bars (although some are interchangeable)
which means IF u ever go to a LARGER/heavier trailer a new hitch will be needed.
direct HELP from the e'I'zer TECH people is in this thread...
(( ignore MOST of the forum expert's posts below, and read #44 and #90...))
http://www.airforums.com/forums/f232...use-28204.html
with set up help here...
http://www.airforums.com/forums/f464...ion-32805.html
the w/d bars need to FLEX 1-3 inches in order to maximize the friction sway cams (reese) or 4 point control (eIzr)...
500-600 lbs tongues=600 lb bars.
650 lb tongues=1000 lb bars UNLESS towing with beefier mule.
at 450 lbs many question the need for w/d but with your tv, 600 works...
and u can toss a case or 2 of beverages UPfront to add tongue weight
ONE w/d bar?
i don't think a LOT of sway dampening will happen, unless you ADD friction outriggers to the set up...
and that is REALLY old school
cheer
2air'
Old 04-13-2010, 12:39 AM   #15
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
I found the address for the manufacturer of Draw-Tite = "Cequent Towing Products" - looked up the phone number for the corresponding address and found the following:
Cequent Towing Products / Draw-Tite
47774 West Anchor Court, Plymouth
(734) 656-3000
Hope that is of some help
**I Love U.S.A.**
Old 04-13-2010, 06:53 AM   #16
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I know everyone has an opinion . I use the Reese Straightline Old Style Dual Cam with 550 bars with our F350.The TV and Trailer get a very nice smooth ride. I know the trailer is short but Im sure you will be pleased with the dual 600 lb bars.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-13-2010, 08:39 AM   #17
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Thanks everyone for your input. I have locked down a reese system with 600# bars and a prodigy brake controller.
I am picking up the trailer on Friday and will be posting pictures soon. Thanks again.
Draw Tite WD Hitch greatlakes Hitches, Couplers & Balls 6 12-11-2009 08:33 PM
Does Draw-Tite = Reese? Sparkygus Hitches, Couplers & Balls 12 06-05-2007 03:47 PM
Draw-Tite/What's it gonna do for me? pamelake Hitches, Couplers & Balls 7 04-23-2006 03:03 PM
Shorten Draw Bar? dmac Hitches, Couplers & Balls 10 10-23-2003 12:35 PM
