Originally Posted by jacobwellcom
Someone on the Burnstream list
In both cases it was apparently sway that overwhelmed their control. Very sad. I have hardly any experience towing, but those pictures seem like a pretty strong argument for sway control (and they may have had sway control - things happen - but anything that would reduce the likelihood seems worth it). Certainly makes me think I'll be getting the rest of the parts for the Reese dual-cam hitch that's on my trailer before going on any trips with it.
This post clearly shows why folks like me (and you know others are out there too) why you SHOULD NOT TOW with the wrong T.V. That Bronco's wheelbase was WAY TOO SHORT to be towing that size Airstream or that size anything. I never saw the hitch setup, but even if this person used the proper hitching gear, including sway control, it might have only given a slight advantage IMHO given that they appear to have started with the wrong tow vehicle to start with. Looking a bit further, they had 4 people in the truck. This was nearly exactly what I saw on my way back from the summer of 04 Midwest Rally. Too much trailer for too little of a T.V. Now the one I saw didn't have sway control or weight distribution either which was simply the trifecta of stupidity. I can't say that in this case.
What I can say is that the the price of the cams, why not? I have towed with and without the bars, with and without the cams and I have to say, it was a far more comfortable exp with them, particularly in higher than normal wind conditions. If we were talking about the cost of the cams and comparing that cost to that of say a Hensly ($3000) I might have a different take, but I paid something like $200 for the cam system and it works!
I followed Inland RV's suggestion of not being overhitched and downgraded the bars so that I would get some flex. Worked great!
