Old 07-17-2007, 09:53 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Reese & Equalizer: Functional difference?
I am currently using an older Reese wdh (chain and flip clip) which seems to work OK, but I have never been happy with the flip clip attachment. I dont like how they attach and I have bent a couple up. I have considered welding the things to the tounge, but for all I know that is dangerous.
I notice that that the Equalizers use a chainless mount which I am thinking I might be more comfortable with.
So here is what I am wondering. Is there any functional differences between the two sytems? Am I just not set up corectly, wrong bars? Am I just perseverating on somthing that is no big deal? Any ideas on this one folks?
Other information: I am level when attached, the only sway issues (so far) come from large trucks passsing. Above 65 mph, the set up can be a little 'loose' (for lack of a better term) but I tend to go 55-60 anyway. Oh yeah, TV is a 1991 f150 manual trans with 302 if that matters.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 07-17-2007, 10:01 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Hey Rodney,
You'll get lot's of opinions on this....sort of like an oil thread! I use the Equal-I-Zer and it works flawlessly. The Reese works well also. Both MUST be properly installed and adjusted. I have never experienced any sway in 12,000 miles of towing the CCD, sometimes at speeds of 75mph.
I chose the EQ for the simplicity of attachment. Your results may vary .
Old 07-17-2007, 10:05 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by lewster
...sometimes at speeds of 75mph.
tsk, tsk, tsk...shame on you!
Shari
Old 07-17-2007, 11:05 AM   #4
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Shari
Family of Disney Fanatics
WBCCI# 4821
Old 07-17-2007, 01:03 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you set the Reese up right it should not move. Do you have a twin cam or just the weight distribution system with the frictional dampener? Pictures might help if you have them. Otherwise take it to your local WBCCI meeting and you will be flooded with volunteers willing to tell what you should do. Only believe half of them (the other half does not really understand the particulars of any setup).
Old 07-17-2007, 01:05 PM   #6
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
It is a weight distribution system with friction damper. The nearest WBCCI unit that I would want any part of is 1200 miles to the west.
Rodney
and the
My Blog
Old 07-17-2007, 01:09 PM   #7
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Lew gave a good answer. Properly adjusted either one should be good. I would add that I also have the Equal-i-zer. Just completed my first long trip. 1,000 miles across Wyoming and back. Strong quartering head wind and side wind on the blue hwy from Cheyenne to New Castle on the way out. Stayed between 60-65 MPH. No sway and couldn't tell any difference when met or passed by large trucks. Bikers were few that day but the ones out were leaning well into the wind. I replaced the older Reese that came on the Minuet with the Equal-i-zer but only because the Reese didn't have any sway control built in.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 07-17-2007, 05:09 PM   #8
1975 29' Ambassador
Reno , Nevada
From the reports in the various RV forums, both are a step better than they typical RV supplied friction bar. Both seem to be about equivalent in performance.
Both the Eq and the DC are friction damping devices although the DC is sold otherwise. (calculate the friction on the 'cam' vs the cam forces and see for yourself). Both can be noisy in turns.
The DC is a good choice if you already have a Reese or EAZ Lift hitch as it can be added.
The Eq does not require any holes or welding to the A frame and may be a better choice if you are starting anew with a hitch.
On the Eq, you adjust the friction with bolt torque. With the DC, you have to more carefully set the load on the spring bars to influence the damping.
Whichever route you go, make sure you get a hitch and spring bars properly rated for your tongue and trailer weight. Keep in mind Dallas' adjustment guide:
"Adjust the hitch ball height to 'level' the trailer"
"Adjust the weight distributing bars to 'level' the tow vehicle"
"Adjust the hitch head angle to 'level' the bars."
I do note that those installing the Eq often seem to have a lot more 'fun' playing with adjustments to get their rig 'just so' as if a few millimeters might make a difference. ;-)
The DC seems to be more popular in the Airstream crowd although the Eq population is growing. (did anyone do a hitch census at the I'Rally?)
Old 07-17-2007, 08:35 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I have no idea what a DC is. Are you refering to the Reese hitch?
Rodney
and the
My Blog
Old 07-17-2007, 08:40 PM   #10
lewster's Avatar
Rodney,
DC = dual cam sway control
Old 07-17-2007, 08:57 PM   #11
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Thanks, I dont think that applies. I have spring bars connected by chain to filp clips.
Rodney
and the
My Blog
Old 07-17-2007, 09:22 PM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've owned both the Dual Cam and the Equal-i-zer. When I upgraded to the Classic I was pretty much forced to also do a hitch upgrade due to the hitch weight exceeding 1,000 lbs. While I was happy with the dual-cam, I kept hearing about the good experiences folks were having with the Equal-i-zer. I asked my dealer and he said that in his experience Reece customers who switched to the Equal-i-zer were coming back with positive reports.
Personally my dual cam was used with a 27' Safari. The current trailer is a 30' Classic Slide. The tow vehicle is the same that handled both trailers. From my side the Classic seems to be much more stable in cross winds and when passed by tractor trailers. Not that the Safari and Reece dual cam combo was bad, I just don't feel the little wiggle with the Classic Equal-i-zer combo that I used to notice with the Safari. Now is the heavier hitch weight the difference or the fact that the Classic weights about 2,000 lbs more? I'm not sure. But my experience seems to fit into what the dealer told me.
Bottom line they are both good hitches. Each just uses a different method to fight sway.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-17-2007, 11:09 PM   #13
1975 29' Ambassador
Reno , Nevada
This is typical of the Reese and EAZ Lift type hitches. The Dual Cam is an additional mechanism that connects near the ends of the spring bars (where the chain attaches to them) to a 'cam' via a short 'lever' - the picture at Hitch Setup shows an old DC. Because the DC can be added on to the most common load leveling hitches, and costs about half that of a new Equal-i-zer to add on, it is a common upgrade sway control.
Also note that Blue Ox makes a similar sway control hitch that functions like an Equal-i-zer but uses a trap for the chains lifting the spring bars rather than the L bracket that the Eq uses.
sorry for the jargon. EQ is shorthand for Equal-i-zer brand and DC for the Resse Dual Cam brand.
If money is no object and (deleted) then the Hensley Arrow or Pullrite hitches are the way to go. These control sway by moving the pivot point forward making the trailer behave more like a 5th wheel rig. The HA, in particular, has very enthusiastic fans. I am surprised they haven't chipped in here yet extolling its virtues! ;-)
Old 07-17-2007, 11:55 PM   #14
lewster's Avatar
Shari
Of course, that 75 MPH speed was attained briefly at the TOP of a 6% grade that was 4 miles long with the 155 HP diesel in my Sprinter.
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
Reese hitch on semi-steep slopes? 3Ms75Argosy Link Archive 1 09-15-2002 12:08 PM
Reese Electra Lift Road Ruler Jacks, Stabilizers, Lifting and Leveling 0 08-22-2002 04:12 PM
