Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 07-29-2003, 09:17 AM   #15
qqq
qqq's Avatar
Profile:
Chuck,
Well, I do have Airlift airbags... but look at my avatar , all is perfectly leveled
The rest of the world "fact" is a FACT . WD are unknown there.
Hart
qqq is offline   Reply With Quote
Old 07-29-2003, 09:31 AM   #16
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Originally posted by qqq
Chuck,
Hart
Hart... you are obviously pleased with the balance and handling of your truck and trailer, and I think that's great. You need to understand though that you have one of the few truck-trailer combos in the country that apparently don't require WD/sway control.
If it weren't necessary for the rest of us, believe me when I say we wouldn't be spending the time and money to use it.
I understand your contention that WD/sway control is essentially unused except in North America. I don't know why that is, but it really doesn't matter much for our purposes.
The fact is that the vast majority of us need some kind of WD and sway control to keep our towed load's weight equally distributed for handling and performance, and our rigs safely under control at highway speed. It's not a luxury, it's a necessity. Even when we have it, as I did, it may not be set up right, which leads to an unsafe towing situation. I was fortunate in that the sway episodes I've experienced have been minor, and I've been able to control the rig. Others have not been as fortunate and have crashed.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 07-29-2003, 11:07 PM   #17
qqq
qqq's Avatar
Profile:
Roger,
I refered to trailers under 23 feet, not your 34 behemoth
Hart
Old 07-30-2003, 06:13 AM   #18
85MH325
85MH325's Avatar
Images: 37
Roger,
Hart
I had sway problems on a bare ball with my Astro and a '61 Bambi 16'!
The size of the trailer isn't important. The factors that ARE important are: the trailer to tow vehicle weight ratio; tow vehicle tow weight rating; tow vehicle tires; tow vehicle wheelbase; tire inflation on both trailer & tow vehicle; trailer weight; tongue weight; distance from the tongue to the axle placement; and trailer loading and balance.
If any one of these factors is out of balance, sway can become a loss of control issue. Sway control and weight distribution equipment counter the trailer's propensity to start oscillating from side to side (yaw or sway) with the application of side forces.
Roger
Old 07-30-2003, 07:30 AM   #19
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Under 23 feet a ball is enough unless you tow with a Yugo.
The whole world (except US & CDN) has done it since trailers exist, some lighter ones are towed by light cars & the heavy ones by larger cars...but only with a ball...& thats a FACT
Hart
Our 59 Caravanner 22ft had to be moved and at that point we were unable to locate the hitch (long story as to why). Totale max weight of the trialer should be about 4k ready to go.
We used a straing ball set up to move it and I tell you it was the most terrifying ride EVER. I will NEVER pull a trailer over 2,000 lb and 15ft of length without some sort of sway control. Our new tow rig is a 3/4 ton Suburban. It has STIFF suspension and dropping the traler on the ball drops the rear of the truck 1.5 inches and riases the front .75 inches. I have approximatly 550 lb of toung weight. I use 750lb bars and it seems just right. Front is .25 inche up and rear is .25 inches low.
I'm using a Dual cam that was a E-Bay find that came with a seto of 1k bars, Had to buy a second draw bar to work properly with my truck. I had the PO's 750lb bars that I use with the camper. I have $300 in the system. The 1k Bars work perfect with a friends car trailer I barrow on occasion.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 07-30-2003, 04:23 PM   #20
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Roger,
Hart
Yea Roger.....don't you have a button for sway control on the monster anyway!
Eric
Old 07-30-2003, 04:27 PM   #21
85MH325
85MH325's Avatar
Images: 37
Eric
No, it flies; fires phasers; carries photon torpedoes; has a hanger deck; and can do warp 9; but there's no sway control button.
Roger
Old 07-30-2003, 04:38 PM   #22
Silvertwinkie
Aluminut
See Cloud! Another Trekie!
Old 07-30-2003, 05:04 PM   #23
MW64OVERLANDER
MW64OVERLANDER's Avatar
Profile:  1964 26' Overlander
Norman , Oklahoma
Images: 67
Are the sway control bars stamped with a number indicating what pound bars they might be or is there another way of identifying what their rating is.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 07-30-2003, 06:08 PM   #24
63flyingcloud
Profile:
ARRRRRGHHHHH! It's like they're everywhere!!!!!
63flyingcloud is offline   Reply With Quote
Old 07-30-2003, 07:08 PM   #25
85MH325
85MH325's Avatar
Images: 37
The Trouble with Tribbles...
Yep, Cloud... just like TRIBBLES!!!!!
Roger
Old 07-31-2003, 10:08 AM   #26
63flyingcloud
Profile:
Talking
Too funny!
Tom
Old 07-31-2003, 10:22 AM   #27
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Yes, well at least both sets of Resse bars I have. It is a code so you would probably have to contact a dealer to figure that out. Both sets of my bars also have a sticker that clearly says 750lb or 1,000. One set of bars those stickers are getting in pretty rough condition.
1959 22' Caravanner
Atlanta, GA
Old 07-31-2003, 10:42 AM   #28
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
My DrawTite bars were identified with a thin plastic label that lasted a few months before peeling off. There is some code stamped into the metal at the elbow, but I have never lookat it closely.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Which Weight Distribution Hitch to buy? Navigator Hitches 7 11-19-2003 08:56 AM
how works a weight distribution hitch remcolent Hitches 5 11-10-2003 07:24 PM
Weight Distribution Question Randy Johnson Hitches 63 07-21-2003 11:57 AM
Weight Distribution newae On The Road... 9 07-18-2003 11:08 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 03:48 PM
