Old 03-29-2008, 07:43 PM   #1
1998 30' Limited
garden Ridge , Texas
Question Receiver question on HD2500
I have a chevy silverado HD2500 with the Duramax Allison combo, and tow a 1998 30 foot classic limited. Do I need to consider replacing the receiver that came on the truck or is it OK like it is. I also have a Hensley Arrow that came with the trailer. It seems to be working fine, but someone told me that it might be inadequate and could actually fail.
Crawdad is offline   Reply With Quote
Old 03-29-2008, 07:48 PM   #2
chaimemet's Avatar
2008 31' Classic
Ft. Lauderdale , Florida
tow hitch
i have a GMC 2007.5 2500 crew 6.6 bed duramax and a hensley hitch. The receiver is a 2 1/2" with an adapter for 2" hitches. There is no problem that I can see and I have towed 2x in the last 3 months total of 1600 miles. The AS is an 08 31 Classic.
chaimemet is offline   Reply With Quote
Old 03-29-2008, 08:30 PM   #3
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
I believe your receiver is fine. I think they beefed the 2007 hitches up from what I have on my 2006 Silverado. I tow 30' classic no problems, but I do inspect it regularly.
Why would someone tell you the Hensley may be inadequate and could actually fail? Its the best hitch on the market, especially for your size of trailer. Is there something wrong with it? 1400 lbs Weight distribution bars?
Post some good pictures of it. There are many here that can help if something is wrong with it, and Hensley is very helpful also if you have a problem.
Good Luck and Enjoy
Dale
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 03-29-2008, 08:39 PM   #4
1998 30' Limited
I was unclear with what I said. Its not the Hensley that they said might fail. It was the receiver that they were referring to. Some have said I need to replace it with a Class V receiver.
Old 03-29-2008, 08:41 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
The OEM 2" receiver on my 2005 GMC Yukon XL 2500 did fail. The weld broke next to the receiver box. I replaced it with an aftermarket Class V receiver. I just purchased a 2004 Chevrolet Suburban 2500 as a backup tow vehicle. I plan to replace the OEM receiver with a new Class V.
SuEllyn & Brian McCabe
Old 03-29-2008, 08:57 PM   #6
_
hi crawdad...
here is a the thread on this issue with the older ge'ems...
http://www.airforums.com/forums/f464...les-34603.html
the haha does put more stress on the receiver box in the rotational and side2side planes...
so IF the receiver box shows any signs of sloppiness after towing some, replace it.
cheers
2air'
Old 03-29-2008, 09:15 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you deal with hitch weights in excess of 1,000 lbs., not all GM trucks are equipped with receivers to carry that weight. On my GMC van, I had to pull the factory receiver and upgrade to a class V receiver to deal with the 1,200+ hitch weight on my 30' Classic Slide Out.
If in doubt check the sticker on the receiver and your hitch weight on the trailer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-29-2008, 09:54 PM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Is it round or square?
Michelle TAC MT-0
Sarah, Snowball
Old 03-29-2008, 10:46 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
What year is your 2500 HD? They did upgrade the hitch receiver, but I'm not sure whether it was on the 2007 or 2008 models. Mine, a 2008 does have the 2 1/2 inch receiver, which was advertised as a major upgrade in strength. My 2003 Suburban's receiver on the other hand needed to be replaced.
Paula
Old 03-30-2008, 06:15 AM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Your profile says the truck is a 2007 HD2500. The hitch weight rating should be stamped on the receiver or be found in the owner's manual. My old 2001 model had an engineering Bulletin issued for it to warn of the dangers. DOT had a number of complaints. If in doubt, buy an aftermarket class 5 receiver.
Old 03-30-2008, 06:33 AM   #11
gowyn's Avatar
2007 27' Safari FB SE
London , ontario
when I had my haha installed the dealer beefed up the stock hitch, couple pieces of angle iron welded on and good to go. I think the problem is the tubing is round so the square reciever rotates up and down thereby creating unusual stresses on the welds. With the extra bits welded on I'm good to go.
gowyn is offline   Reply With Quote
Old 03-30-2008, 02:21 PM   #12
1998 30' Limited
I checked and the sticker on the receiver says it is good for 1500 lbs hitch weight and up to 12000 for the trailer weight, so I am probably safe for what I am towing now. My truck is a 2007 classic which means it is the old body style, purchased in November of 2006. I suppose I will just check it fairly often for signs of failure, and if I ever go to a 34 footer, I will definitely change out for a Class V. Thanks to all for your support.
Old 03-30-2008, 07:15 PM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
GM Recievers
Just took this off our "new" 06 Burb today.
Hard to believe it's rated for 12000lbs. If yours looks like this, round bar,
I highly recommend replacement. I still put time in at a Chevy Store and
we have replaced at least six in the last year.
Name:	1 06 SUB HITCH.jpg
ID:	57299   Click image for larger version
Name:	2 06 SUB HITCH.jpg
Name:	5 06 SUB HITCH.jpg
ID:	57301   Click image for larger version
Name:	6 06 SUB HITCH.jpg
Name:	4 06 SUB HITCH.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-30-2008, 07:32 PM   #14
1998 30' Limited
Robert,
That is exactly what mine looks like. Did the six units that you replaced in the last year fail...or did the owner replace them for fear that they would fail? Either way, I will probably replace mine.
Drop Receiver, Yes or No? RBolton Hitches, Couplers & Balls 6 12-11-2007 08:34 PM
Receiver Changeout 7xp Hitches, Couplers & Balls 2 06-30-2007 08:12 AM
Receiver/hitch weight with WD Devoman Hitches, Couplers & Balls 15 12-21-2005 07:04 PM
class iv or v receiver? 2airishuman Hitches, Couplers & Balls 11 03-08-2005 07:27 AM
Receiver Extension bugdoc 1997 - 2004 Bambi 10 11-17-2004 04:41 PM
