Old 07-16-2009, 04:26 PM   #99
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Originally Posted by MJBear View Post
I know there has been talk of "separation" from the shell. I cannot grasp how adding less than 100 lbs directly to the back of the frame will cause it to separate from the shell.
I can see how it could happen. Andy has nicely outlined some of the physics involved, but as in most things in life....the devil is in the details.
I refer you to a post by another well respected Airstream dealer, Andrew Thomson of www.can-am-rv.com/ ...
http://www.airforums.com/forums/show...8&postcount=19
As Andrew indicated, bowing to pressure from customers who insisted on a rear-bumper carrier (like me), he designed a light-weight bumper rack that would carry bikes (max 2) on the rear bumper with minimal structural risk.
When I spoke to Andrew, he made it clear that he did not recommend rear-mounted receivers; a 2" receiver and bike carrier adds well over 100 lbs before you add the bikes which are typically projected well beyond the rear of the trailer, so the risk of structurally damaging an A/S grows signficantly.
Instead, what Andrew designed was a custom solution using a folding two-bike carrier from www.toppoprails.com/ custom mounted using Zip-Dee hardware. The result is a bike rack that is attached to the rear trailer shell/bumper that weighs all of 12 lbs. Add two 30 lb bikes and your running about ~70 lbs total 2 feet off the rear shell.
Is the risk of rear separation zero? No. But I'm no dummy and it just didn't seem reasonable that Airstream's couldn't handle an extra 70 lbs in the same location as their bumper storage compartment (ours is empty BTW).
Keep in mind this is not an ideal solution -- it partially restricts access to the rear storage hatch (though the carrier does fold down out of the way) and is much more expensive relative to all other solutions, but for us it represented the best option.
I have photos and including close ups of the rig on my photos pages...
http://www.airforums.com/photos/browseimages.php?c=500&userid=19566
Keep in mind the rack needs to be custom mounted -- it's not a plug'n play design.
Cheers!
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD Hensley DirecLink McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 07-16-2009, 05:15 PM   #100
Holladay , Utah
I use this method to carry my bikes in the bed of my pickup. When I get home I just pick up the 4X6 and hang them on the wall of the garage. Its a good travel and storage solution.
jmallgood is offline   Reply With Quote
Old 07-17-2009, 05:16 AM   #101
MJBear's Avatar
2000 31' Excella
St Michaels , Maryland
Thanks for all the information from everyone. Carrying toys along is the biggest (and only) problem when traveling in an airstream. Our kayaks sit flat and take up all the space on the cap and truck cab, so bikes up there aren't an option. If Thule made a rack for our truck then our old Thule system would work and bikes could be in the middle - but that is more cumbersome and less accessible than where they are inside. They are ok inside the cap, but as I said, not at all convenient for those stops when you stay hitched and would like a bike ride and also they take up most of the space.
I do understand, Andy, your explanation of the torque when hitting a bump, but you referred to hanging them on the bumper and the problem there makes good sense to me. But if they are welded to the frame and do not have much "swing" that should be minimized and if they aren't fastened to the shell it shouldn't effect the movement of the shell to frame.
As for a front mount on the truck I would think they would get terribly dirty?Wouldn't they block lights? They for sure couldn't be covered. I guess folding bikes is an option as well. Also thinking about an inflatable kayak for some trips that aren't specifically for the purpose of kayaking.
MJBear is offline   Reply With Quote
Old 07-17-2009, 07:03 AM   #102
Unfortunately and out of necessity, the shell holds the frame up. especially at the rear.
Anything you carry in the rear has an effect on the shell.
The question is always, "how much of an effect?"
Small things, no problem.
Your proposal, big bucks problem.
Old 07-17-2009, 07:22 AM   #103
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
With our previous trailer, a 27' Award, which we had for about ten years, I carried our two bicycles on a hitch rack fitted to a 2" receiver mounted on the front of our truck.
You are right that it does have some impact on your lighting, but not a major one. In any case, we rarely travel at night.
Technically, I am not sure if it is 100% legal because of the lighting issue and also because - if you want to be picky - the handlebars & seats do intrude slightly into your field of vision.
Having said that, we have never been stopped for it in ten years of cross country travels.
When we bought our Airstream last Fall, I was initially pleased to find that it had a 2" receiver on the rear. I planned to move the bikes to the back of the trailer.
We toured the AS factory when we bought our trailer and I spoke with the tour guide about using the hitch for bicycles. I knew that the manual that came with the trailer stated the AS position that nothing should be carried at the back of the trailer.
His opinion ( as a long time AS owner and employee for many years) was that bikes should cause no problem and that the wording in the manual was aimed to stop folks hanging heavier and heavier loads off the back. So I still figured I would do it!
Then I read the wealth of info on this forum, mostly negative with respect to trailer hitches on the rear of the AS.
I understand the arguements, but am still not entirely sure that the forces would cause separation.
Nevertheless, we paid a bundle for the trailer and so in the end I decided not to chance it. Since I was not going to use the hitch, and since it was pretty heavy itself and reduced ground clearance significantly, I cut it off before our first long trip with the trailer and I continue to carry the bikes up front on the truck. It is the solution that works best for us. We have a cap on our truck, but fully use that space for storage to keep clutter out of the trailer. The truck is a 4x4 and I think it would be just too much of a struggle to get bikes up and down off the roof.
Brian.
Ps - I suspect the previous owner must have pulled a small trailer behind the AS, perhaps a motorcycle or boat, as there was a wiring harness as well as the hitch. As far as I could tell, it had caused no damage at the back of the AS, but who knows - I'm keeping my fingers crossed and hoping that maybe he only used it once!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-17-2009, 09:20 AM   #104
MJBear's Avatar
2000 31' Excella
Our truck is also 4X4, quite high and that is why we put our kayaks up there flat and roll them up. It is the only we we could do it, so to put bikes in the middle we would need a scaffold.
I'm familiar with Awards - had wanted one for years, then when kids were grown and we thought it would be the perfect trailer for 2 they were out of business. That is a really light trailer and seems like it should have had as many if not more issues with a back load than an airstream. There are lots of trailers and 5th wheels headed down the road with all kinds of stuff hanging of the back and most not made as well as our airstream. Many rv's a whole lot longer with a great deal of overhang as well. What makes it such a problem for Airstreams?
I'm still wondering if anyone has actually experienced separation from weight on the back. From responses so far the folks who have actually put their bikes on the back are saying its been ok and there haven't been any negatives. On our last drive to Georgian Bay above Toronto we passed several airstreams - 2 with bikes on the back which is what got us interested again.
Old 07-17-2009, 09:22 AM   #105
MJBear's Avatar
2000 31' Excella
Sorry I realize I misread about the Award --- the bikes were not on the back but on your truck.
Old 08-30-2009, 07:16 PM   #106
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Yea, I know it's dangerous to post here again... but
So I decided to pursue to store-inside-the-AS option. We're heading out on Sat. for the outer banks and I would like to take the bikes with us. I envisioned a simple wood structure that would hold the front axles of our two bikes and then I would bungee cord the front wheels to the fixture. Well, fine until there's a side load (i.e. turning). Then, the whole thing goes to heck in a handbasket. So, after my wife and I contemplating for about 30 minutes as to where / how we could attach the bikes to the something in the living room of the AS without drilling / damage / eyesore; we gave up for the night.
So now my reason for posting here again: those of you that have made in-the-AS bike holders...please post pictures or email them to me directly as jasongrendahl@gmail.com. I need to see your ideas and figure out how you keep the bikes from falling over and taking your "rack" with it. Where do you screw to in the trailer or how are you otherwise reacting the loads of turning?
WineStream is offline   Reply With Quote
Old 08-30-2009, 08:25 PM   #107
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Interesting idea, I'm sure it's been done many times, and always with creative, thinkin' outside the box solutions.
My first knee jerk reaction is to perhaps use a tension rod (think temporary curtain rod) across the width of the trailer. It's removable and wouldn't damage the walls. Then you could add a few hand clamps to the rod to prevent the bike from leaning. It's kind of a crude idea, but it's probably about 20 bucks in parts, so it might be worth a try.
bredlo is offline   Reply With Quote
Old 08-30-2009, 08:45 PM   #108
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Visit this thread for airstream bike racks.
http://www.airforums.com/forums/f161...ams-41078.html
mojo is offline   Reply With Quote
Continental Travel Trailer coo978 Off Topic Forum 0 11-18-2007 01:51 PM
Back-up Monitor for Travel Trailers. Inland RV Center, In Commercial Listings 67 04-15-2007 07:29 AM
Motorhome vs Travel Trailer DEO Airstream Motorhome Forums 15 02-16-2007 07:45 AM
Travel trailer vs. motorhome gardener Community Polls 51 01-06-2006 07:40 PM
travel trailer security bluegrass Our Community 6 09-04-2005 09:05 PM
