Old 06-02-2008, 03:47 PM   #43
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by Road Ruler
I understand completely.
The secret here is to have 50 lbs "at" the bumper but have it supported further up toward the axles. It can be done. Think about it. Engineering!!!
The old time and money bit.
I like Blevi's idea. I myself bit the bullet and got a Yakima for the roof of the burb. I can hold about 4 bikes up there.
Originally Posted by HowieE
Good try Andy
What you forgot is 50 lbs acting at 10 ft in not 500 lbs it is 500 ft. lbs. Ft lbs are a measure of troque not weight. You will have 50 lbs of weight at the bumper and on the axles on any scale you go over.
I'm smelling a retired engineer.......
Silvertwinkie is online now   Reply With Quote
Old 06-02-2008, 03:58 PM   #44
The bumper support is the "shell" not the frame.
Adding all the weight you want to to the frame, just makes it harder for the shell to support the frame, because of the added weight.
Monocoque, means a load bearing shell.
That's the principal method of construction of an Airstream trailer.
So, beefing up the frame, adds weight to the trailer, costs you money for the steel and labor, yet adds nothing to the integrity of the shell to frame attachment.
And as an added negative benefit, the more beefing up someone may do to the frame, rearward of the axles, adds weight to the trailer, AND, removes some tongue weight.
Old 06-02-2008, 05:22 PM   #45
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Take the advice above. When we got our 67, it had a nice, square hole in the back bumper (guess what that was), and one really bad case of frame separation. The hole is now gone, and so is the frame separation, but only after some major elbow grease and a wad of cash.
Lynn
WBCCI 21043
Old 06-02-2008, 05:54 PM   #46
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you don't think it matters, try holding a 5 pound bag of sugar on one end of a ten foot long pole, and lift it by the other end. It is much different than holding that 5 pounds in your hands. Then, while holding the same 5 pound bag of sugar on the end of the pole, jump up and down with it.
Our trailer suffered (and it's still not right yet) rear end sag from just the added weight of a 10 gallon grey tank all the way in the back, and 10 gallons of water weighs 80 pounds. This would be the equivalent of 50 pounds of bicycles and 30 pounds of mounting hardware.
Old 06-02-2008, 05:54 PM   #47
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Why don't you use one of the bike carriers that are made in Canada and mount on the front tongue. The bikes are carried above the propane tanks. I've seen one of these and they work well from what I was told. There is a trread about these on here somewhere. Here is a link to their website.
WELCOME to Top Pop Rails Website !
Al - K4GLU is offline   Reply With Quote
Old 06-03-2008, 04:05 PM   #48
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Here's what I use...
The total weight of the bikes and rack is probably less than the weight of a 2" hitch receiver and bike rack without the bikes. I would agree that installing a 2" receiver might be a mistake, but I'm comfortable with this custom setup. If it causes any structural problems I'll be sure to let everyone know...
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD Hensley DirecLink McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 06-03-2008, 04:35 PM   #49
Dozens of people have already posted, that it "WILL" happen.
But, it's still your choice.
Again, Airstream will void any warranty claims as a result of what you want to do.
That in itself, states their position.
Old 06-03-2008, 04:42 PM   #50
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Dozens of people have already posted, that it "WILL" happen. ... Again, Airstream will void any warranty claims as a result of what you want to do. That in itself, states their position. Andy
Hi Andy:
So what was the length of Airstream's warranty period on Garfield's 2001 travel trailer? Has the original warranty expired, or is it still in effect?
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 06-03-2008, 04:43 PM   #51
HowieE's Avatar
Princeton , New Jersey
Images: 12
Garfield
That a good looking and well engineered rake. The one I use and have use as an illustration is no longer available so if you would can you post the maker and modle number. There are lots of Airstreamers looking for this.
Can you post a closer picture of how it attaches to the upper section to the rear of the trailer.
2004 Excursion 4x4
Old 06-03-2008, 04:57 PM   #52
Originally Posted by 47WeeWind
Hi Andy:
I am sure his warranty has expired.
The point was Airstream says, NO NO.
But as always, it's the individuals choice.
But choices like that make service centers happy, in that "A" they charged you to do it (usually), and B, they charge you to fix it. They can't lose, but the customer, as many have pointed out, will, in time, see the negative results of that choice.
It really doesn't matter to me, because it seems that no matter how well the resulting problems are documented, some people still have to do it.
Old 06-03-2008, 05:11 PM   #53
Well Preserved
1993 21' Sovereign
Guys (and gals), the question has been asked, answered, rebutted, discussed, cussed, hashed and rehashed. At this point I think anyone that looks at this thread will have a very good idea of the pros and cons of making this suggested modification to their Airstream. At this point I think any further discussion will just be a further review of points already made, so unless something drastically changes in the future, we should all consider the subject closed, and let future viewers make their own decisions on what is best for them based upon the facts and opinions expressed here.
Thanks for keeping to the subject at hand, and not allowing things to degenerate into arguments and personal attacks, it's nice not to have to step in with the ol' moderator hat on.
Old 06-03-2008, 05:14 PM   #54
Amen and a half.
Old 06-03-2008, 05:37 PM   #55
HowieE's Avatar
Images: 12
Considering this topic is posted at least once a month and will posted again I would ask that you leave it open long enough for Garfield to post the model number of his rack.
Are we here to provide open discussion and information or just tow the company line?
2004 Excursion 4x4
Old 06-03-2008, 05:44 PM   #56
Well Preserved
1993 21' Sovereign
That's why it's still open.
Continental Travel Trailer coo978 Off Topic Forum 0 11-18-2007 01:51 PM
Back-up Monitor for Travel Trailers. Inland RV Center, In Commercial Listings 67 04-15-2007 07:29 AM
Motorhome vs Travel Trailer DEO Airstream Motorhome Forums 15 02-16-2007 07:45 AM
Travel trailer vs. motorhome gardener Community Polls 51 01-06-2006 07:40 PM
travel trailer security bluegrass Our Community 6 09-04-2005 09:05 PM
